July 05, 2024, 13:16
Technical Help & Discussion
new mobo/cpu/memory - system not booting
Topic: new mobo/cpu/memory - system not booting (Read 1741 times)
skurken
New Member
May 29, 2003, 01:08 »
hey again
just got my asus p4pe mobo, p4 2,4 and 512mb ddr ram. installed everything correctly, pressed the ON switch...........nothing!
my power switch is connected correctly to the mobo and the mobo gets power(green led is on)
any ideas?
Sandra
Ultimate Member
Re:new mobo/cpu/memory - system not booting
May 29, 2003, 01:14 »
Any Beeps at all or no noise?
skurken
New Member
May 29, 2003, 01:16 »
no, nothing
Sandra
Ultimate Member
May 29, 2003, 01:26 »
Ok if you didnt get the initial BEEP its usually a memory fault.
Is it a new stick?Can you try a different one?
Have you got just one stick in?Can you try it in different slots?
Its got to be a memory fault Skurken,I am 99% sure of that
skurken
New Member
May 29, 2003, 01:36 »
ive already tried a different slot for the ram..... its a new stick
also the fan doesnt start.....neither the psu one nor the cpu
thanks for replying
Sandra
Ultimate Member
May 29, 2003, 01:46 »
That sounds more like the power isnt getting connected properly then but cant think why.
Is it in a case you have used before with same power supply previously used?
Sandra
Ultimate Member
May 29, 2003, 01:57 »
Just come across this and I remember hearing about this before do you know which voltage your AGP card has Skurken?
AGP Warning LED
ASUS has designed into this motherboard an AGP Warning LED. The AGP Warning LED automatically stops you from turning on your system with incompatible voltage AGP (3.3V) cards, and protects from permanently damaging your motherboard.
Can you let me know which card you are using if you are unsure of the voltage and I will see if I can find it for you
May 29, 2003, 08:55 »
Skurken, check if the CMOS jumper on the motherboard is set to closed. The mobo will not boot if it is.
This has caught me a few times in the past
skurken
New Member
COMPUTER WORKING!
June 02, 2003, 16:58 »
hey again....
It was a faulty memory stick after all.
Now everything is working perfectly after 2months of head-scratching
thanks everyone
skurken
Reply #9 on:
June 02, 2003, 17:10 »
Thanks for letting us know Skurken. I hope you had clear skies for the eclipse last Saturday and that you got up in time to see it!
Sandra
Ultimate Member
Reply #10 on:
June 02, 2003, 17:13 »
Quote from: Sandra on May 29, 2003, 01:26
its usually a memory fault.Can you try a different one?
Thanks for letting us know and glad that its all sorted now Skurken
