Author Topic: This is a test.  (Read 597 times)
Offline Den
This is a test.
« on: June 16, 2015, 22:16 »
This is a test:
1. What do you put in a toaster?
Answer: ‘bread.’ If you said ‘toast,’ give up now and do something else.
 Try not to hurt yourself. If you said, bread, go to Question 2.
2. Say ‘silk’ five times. Now spell ‘silk.’ What do cows drink?
Answer: Cows drink water. If you said ‘milk,’ don’t attempt the next question. Your brain is over-stressed and may even overheat. Content yourself with reading a more appropriate literature such as Auto World. However, if you said ‘water’, proceed to question 3.
3. If a red house is made from red bricks and a blue house is made from blue bricks and a pink house is made from pink bricks and a black house is made from black bricks, what is a greenhouse made from?
Answer: Greenhouses are made from glass. If you said ‘green bricks,’ why are you still reading these???
 If you said ‘glass,’ go on to Question 4.
4. It is 10 years ago, and a plane is flying at 20,000 feet over Germany. During the flight, the two engines fail. The pilot, realizing that the last remaining engine is also failing, decides on a crash landing procedure. Unfortunately the engine fails before he can do so and the plane fatally crashes smack in the middle of Berlin. Where would you bury the survivors?
Answer: You don’t bury survivors.
 If you said ANYTHING else, you’re a dunce and you must stop. If you said, ‘You don’t bury survivors’, proceed to the next question.
5. Without using a calculator – You are driving a bus from London to Milford Haven in Wales . In London , 17 people get on the bus. In Reading , six people get off the bus and nine people get on. In Swindon, two people get off and four get on. In Cardiff , 11 people get off and 16 people get on. In Swansea , three people get off and five people get on In Carmarthen, six people get off and three get on. You then arrive at Milford Haven. What was the name of the bus driver?
Answer: Oh, for crying out loud!
 Don’t you remember your own name? It was YOU!!
 PS: 95% of people fail most of the questions!!
Re: This is a test.
« Reply #1 on: June 16, 2015, 22:31 »
I'm in the 5%.  ;)
Re: This is a test.
« Reply #2 on: June 17, 2015, 08:19 »
All good fun!   :devil:
