Author Topic: IE Tip for Broadbanders  (Read 3302 times)
Re:IE Tip for Broadbanders
« Reply #15 on: June 03, 2003, 00:00 »
Well he did tell you to suck it and see Tony,I think Cammy has some sucking experience from what he posted earlier in DZ,maybe you should ask him  ;D ;D ;D
« Reply #16 on: June 03, 2003, 01:25 »
oh you are awfull Sandra.....but I like you  :-*
« Reply #17 on: June 03, 2003, 01:37 »
« Reply #18 on: June 03, 2003, 21:37 »
To get this thread back onto a hazlenut in every bite or,on TOPIC  ;)
I dropped my cache to 1 mb and it takes ages for my pic and sig to load,it was set as 280 mbs by default as I hadnt altered it from installing XP.
I am now trying it back on 100 mbs and it seems about the same as it was on 280 mbs.
Has anyone else with BB tried it at different sizes and noticed any difference one way or the other ???
« Reply #19 on: June 03, 2003, 22:22 »
Well I reduced mine from 2335Mb to 1000Mb and then after being threatened with physical violence by Adept right down to 100Mb.  I really don't think there is any difference in speed though.
« Reply #20 on: June 03, 2003, 22:28 »
Me? :o :not:
Quiet as a lamb I am :adept: ::) :slug:
« Reply #21 on: June 03, 2003, 22:48 »
quiet as a lamb I am
You know my weaknesses don't you?   ;D  ;D  ;D
