Author Topic: Elephone P7000  (Read 11018 times)
Elephone P7000
« on: July 05, 2015, 19:59 »
No you didn't read that wrong, its an Elephone, managed to get one of these beauties this week end and talk about awesome. its lightening quick and will give the big boys a run for there money. I paid just £135 for mine and its got a 5.5" screen and fast as f*** processor with MT6752 64bit CPU with 5.5-inch FULL HD Screen- 13 Megapixels Rear Camera with SONY IMX214- Support Press Touch ID (360° identify), FOTA, OTG - Equipped with 3GB RAM and 3450mAh battery- Android 5.0 (Lollipop) OS Support
Plus its duel sim ideal for when I'm on holiday plus it makes my Galaxy s5 looks slow.
http://www.elephone.cc/
Re: Elephone P7000
« Reply #1 on: July 05, 2015, 20:28 »
Looks OK, Terry.  I guess there has to be a reason why it's cheap, though.   :-\
Re: Elephone P7000
« Reply #2 on: July 05, 2015, 20:36 »
Made in China ..that's all Simon. but for the life of me can I fault it, only time will tell I guess. :D
Re: Elephone P7000
« Reply #3 on: July 05, 2015, 21:50 »
I guess, being an Elephone, it'll never forget a number.  :basil:
Re: Elephone P7000
« Reply #4 on: July 05, 2015, 22:16 »
And can make trunk calls  ;D
Re: Elephone P7000
« Reply #5 on: July 05, 2015, 23:00 »
 :groan:
Re: Elephone P7000
« Reply #6 on: July 05, 2015, 23:09 »
Re: Elephone P7000
« Reply #7 on: July 06, 2015, 23:15 »
Leaves a big footprint on society o:)
Re: Elephone P7000
« Reply #8 on: July 06, 2015, 23:16 »
 :bawl:
Re: Elephone P7000
« Reply #9 on: July 07, 2015, 11:27 »
Re: Elephone P7000
« Reply #10 on: July 07, 2015, 11:43 »
Hate to think if you had to use a mouse with the elephone  :o :laugh:
Re: Elephone P7000
« Reply #11 on: July 07, 2015, 13:30 »
Eek!   ;D
Re: Elephone P7000
« Reply #12 on: September 24, 2015, 15:10 »
After using the phone for a month now, one of the best phones I have ever used. using it abroad with duel sim 1 with my current provider o2 and one with Data only "3" three all you can eat data it has been brilliant using it when on Holiday. locks onto 4G when in Europe a lot better than the UK. And for only £135 for those doubting it.. :thumbs:
Re: Elephone P7000
« Reply #13 on: September 24, 2015, 15:54 »
Guess it has reason to blow it's own trumpet!   ;D
Re: Elephone P7000
« Reply #14 on: May 09, 2016, 06:00 »
After using the Elephone P7000 ...had moved onto the P8000 and now the current Phone P9000  ;D  :D  :laugh:
Elephone P9000 4G Android 6.0 MT6755 Octa-core 2.0GHz 5.5 FHD 1080*1920p GSM/WCDMA/FDD-LTE RAM 4GB ROM 32GB 3000mAh 13M (B camera) & 8M (F camera) Sony IMX258 Dual SIM Wireless charging
NFC LTPS Type-C Quick-Charge E-TOUCH Off Screen Wakeup Gesture function Smart key
Breath LED APP encryption GPS Wifi FM
Some specs eh!!
