Author Topic: Devolo 1200+WiFi ac powerline  (Read 4908 times)
Offline Den
« on: November 02, 2015, 21:38 »
I had a problem last week with my Devolo 500. Some time ago the upstairs unit stopped working a couple of times but always worked again when I turned off and back on. This time the one in the sitting room stopped working both on wifi and also the dLAN. After a bit of reading up I decided to purchase a Devolo dLAN 1200+WiFi ac from Amazon. I plugged it in and it not only worked straight away but also recognised the older 500 units. Amazingly all the older ones now work but a much higher speed but the WiFi signal is much stronger all around the house.   ;D
Re: Devolo 1200+WiFi ac powerline
« Reply #1 on: November 03, 2015, 10:35 »
Are these the plugs that fit into a 3 pin power socket to boost the WiFi signal around the house?  I don't know anything about them so perhaps you can educate me Den.   :)
Offline Den
« Reply #2 on: November 03, 2015, 12:31 »
Yes they are Clive. They are so good but I didn't expect the dramatic improvement when I moved up to the 1200 version. I now have 100% WiFi signal all through the house and the dLAN behind the Sony Smart TV in the sitting room is so good.   :)
« Reply #3 on: November 03, 2015, 14:38 »
That's good to know - thanks Den!
