Author Topic: wallpaper problem  (Read 1569 times)
Offline Serenity
wallpaper problem
« on: June 05, 2003, 08:11 »
I need help with a PC problem  :-\
Once upon a time I had a certain picture as wallpaper.  I deleted  it and replaced it with another however, when I start up my PC now the original picture flashes up for 10 seconds and then disappears and my NEW wallpaper picture then appears  ::)  can anyone explain how to remove the original picture from startup please?  :-*
Re:wallpaper problem
« Reply #1 on: June 05, 2003, 09:26 »
I think you'll find that that particular wallpaper is still attached to the "default" user.
I'm not sure what OS you are using Serenity so these instructions should work on 95, 98 and ME.
Reboot the PC or Log off the current user
At the Enter Password prompt, press Escape
The default desktop should appear and you should be able to change the wallpaper to something else
I'm not certain, but I don't think the problem occurs in 2000 and XP :-\
« Reply #2 on: June 05, 2003, 13:35 »
Shes on the one thats got the same name as the age she almost is Adept,Windows 98 Second Edition(as she had to be retreaded after she went around the clock twice)  ;D ;D ;D
Offline Serenity
« Reply #3 on: June 05, 2003, 14:26 »
SEE!  I make a sensible posting and the old trout SONDRA  still has a go ::)  right then Im back to the DZ   8)
p.s. thanks Adept  :-*  I will try that out later
« Reply #4 on: June 05, 2003, 14:37 »
This time we will see if we can lock the door more securely to stop you escaping again so easily and disrupting the main part of the forum Serenity,many more posts like that and it will really be a case of the lunatics taking over the asylum  ::)
Offline Serenity
« Reply #5 on: June 05, 2003, 14:39 »
:slug:
