Author Topic: Early February Astronomy Bulletin  (Read 2621 times)
« on: February 07, 2016, 17:25 »
INTENSIFYING COSMIC RAYS
Spaceweather.com
For the past year, neutron monitors around the Arctic Circle have
sensed an increasing intensity of cosmic rays.  Polar latitudes are a
good place to make such measurements, because the Earth's magnetic
field funnels and concentrates cosmic radiation there.  It turns out
that the Earth's poles are not the only places where cosmic rays are
intensifying.  Scientists have been launching helium balloons into the
stratosphere to measure radiation, and they find the same trend over
California.  Cosmic rays, which are accelerated in all directions
(including towards the Earth) by distant supernova explosions and
other violent events, are an important form of space weather.  They
can seed clouds, trigger lightning, and penetrate commercial
aeroplanes.  Indeed, measurements show that someone flying back and
forth across the Atlantic, just once, can absorb as much ionizing
cosmic radiation as from 2 to 5 dental X-rays.  Likewise, cosmic rays
can affect mountain climbers, high-altitude drones, and astronauts on
the International Space Station.  That type of radiation is modulated
by solar activity.  Solar storms and CMEs tend to sweep aside cosmic
rays, making it more difficult for cosmic rays to reach the Earth.  On
the other hand, low solar activity allows an extra dose of cosmic rays
to reach our planet.  Indeed, the ongoing increase in cosmic-ray
intensity is probably due to a decline in the solar cycle.  Solar
Maximum has passed and we are heading toward a new Solar Minimum.
Forecasters expect solar activity to drop sharply in the years ahead,
and cosmic rays are likely to increase accordingly.
MOON FORMED BY HEAD-ON COLLISION
University of California - Los Angeles
UCLA geochemists and colleagues have reported their conclusion that
the Moon was formed by a violent, head-on collision between the early
Earth and a 'planetary embryo' called Theia approximately 100 million
years after the Earth formed.  Scientists had already known about that
collision, which occurred almost 4.5 billion years ago, but many
thought the Earth collided with Theia (pronounced THAY-eh) at an angle
of 45 degrees or more -- a powerful side-swipe.  New evidence
substantially strengthens the case for a head-on impact (the idea of a
collision of that character was initially proposed in 2012).  The
researchers analyzed seven rocks brought to the Earth from the Moon by
the Apollo 12, 15 and 17 missions, as well as six volcanic rocks from
the Earth's mantle -- five from Hawaii and one from Arizona.  The key
to reconstructing the impact was a chemical signature revealed in the
rocks' oxygen atoms. (Oxygen makes up 50% of the rocks' weight.)  More
than 99.9% of the Earth's oxygen is O-16, so called because each atom
contains eight protons and eight neutrons.  But there also are small
quantities of heavier oxygen isotopes: O-17, which has one extra
neutron, and O-18, which has two extra neutrons.  The Earth, Mars and
other planetary bodies in the Solar System have each a unique ratio of
O-17 to O-16 -- each one a distinctive 'fingerprint'.  In 2014, a team
of German scientists reported that the Moon also has its own unique
ratio of oxygen isotopes, different from the Earth's.  The new
research finds that that is not the case.  The fact that oxygen in
rocks on the Earth and the Moon share chemical signatures is very
telling.  Had the Earth and Theia collided in a glancing side blow,
the vast majority of the Moon would have been made mainly of Theia,
and the Earth and Moon should have different ratios of the oxygen
isotopes.  A head-on collision, however, would be likely to have
resulted in similar chemical compositions for the Earth and the
Moon.
Theia was thoroughly mixed into both the Earth and the Moon, and
evenly dispersed between them.  That explains why we do not see
different signatures of Theia in the Moon and the Earth.  Theia, which
did not survive the collision (except that it now makes up large parts
of the Earth and Moon) was growing and probably would have become a
planet if the crash had not occurred.  The team believes that the
planet was approximately the same size as the Earth; others believe it
was smaller, perhaps more similar in size to Mars.  Another interest-
ing question is whether the collision with Theia removed any water
that the early Earth may have contained.  After the collision --
perhaps tens of millions of year later -- small asteroids probably
hit the Earth, including ones that may have been rich in water.
Collisions of growing bodies occurred very frequently back then,
although Mars avoided large collisions.
PLANET IN HUGE ORBIT AROUND STAR
A team of astronomers in the UK, USA and Australia has found that a
planet, until now thought to be a free-floating or lonely planet, is
in a huge orbit around its star.  The object, designated as 2MASS
J2126, is about 7000 times as far from its star as the Earth is from
the Sun.  In the last five years a number of free-floating planets has
been found.  They are gas-giant worlds like Jupiter that lack the mass
for the nuclear reactions that make stars shine, so they cool and fade
over time.  Measuring the temperatures of such objects is relatively
straightforward, but it depends on both mass and age.  That means that
astronomers need to find out how old they are, before they can find
out if they are lightweight enough to be planets or if they are more
massive 'failed stars' known as brown dwarfs.  US-based researchers
found 2MASS J2126 in an infrared sky survey, flagging it as a possible
young and hence low-mass object.  In 2014 Canadian researchers
identified it as a possible member of a 45-million-year-old group of
stars and brown dwarfs known as the Tucana-Horologium Association.
That made it young and low enough in mass to be classified as a
free-floating planet.  In the same region of the sky, TYC 9486-927-1
is a star that had been identified as being young, but not as a member
of any known group of young stars.  Until now no one had suggested
that TYC 9486-927-1 and 2MASS J2126 were in any way linked.
UK astronomers have spent the last few years searching for young stars
with companions in wide orbits.  As part of the work, the team looked
through lists of known young stars, brown dwarfs and free-floating
planets to see if any of them could be related.  They found that TYC
9486-927-1 and 2MASS J2126 are moving through space together and are
both about 32 parsecs (104 light-years) from the Sun, implying that
they are associated.  That is the widest planet system found so far,
and both the members of it have been known for eight years, but nobody
had recognized the link between them before.  When they looked in more
detail, the team members were not able to confirm that TYC 9486-927-1
and 2MASS J2126 are members of any known group of young stars.
Membership in a group of young stars is great for establishing an age,
but when astronomers can not use that method they need to resort to
another.  The team then looked at the spectrum of the star to measure
the strength of a feature arising from the element lithium.  Lithium
is destroyed early on in a star's life, so the more lithium it has,
the younger it is likely to be.  TYC 9486-927-1 has stronger
signatures of lithium than the stars of the the Tucana-Horologium
Association but weaker signatures than a group of 10-million-year-old
stars, implying an age between the two.  On the basis of such an age
the team was able to estimate the mass of 2MASS J2126, finding it to
be between 11.6 and 15 times the mass of Jupiter.  That placed it on
the boundary between planets and brown dwarfs.  It means that 2MASS
J2126 has a similar mass, age and temperature to one of the first
planets directly imaged around another star, Beta Pictoris b.
Compared to Beta Pictoris b, 2MASS J2126 is more than 700 times
further away from its host star, but how such a wide planetary system
could form and survive remains an open question.  At such an enormous
distance it takes roughly 900,000 years to complete one orbit, so it
has probably completed fewer than fifty orbits over its existence.
BRIGHTEST ULTRA-METAL-POOR STAR YET DISCOVERED
University of Notre Dame
A team of researchers has observed the brightest ultra-metal-poor star
ever discovered.  The star is a rare relic from the Milky Way's form-
ative years.  As such, it offers astronomers a precious opportunity to
explore the origin of the first stars that sprang to life within our
Galaxy and the Universe.  The team used two ESO telescopes in Chile
to discover the star, named 2MASS J18082002-5104378.  Follow-up
observations with the Very Large Telescope discovered that, unlike
younger stars such as the Sun, that star shows an unusually low
abundance of what astronomers call metals -- elements heavier than
hydrogen and helium.  It is so devoid of such elements that it is
known as an ultra-metal-poor star.  Although thought to be ubiquitous
in the early Universe, metal-poor stars are now a rare sight within
both the Milky Way and other nearby galaxies.  Metals are formed
during nuclear fusion within stars, and are spread throughout the
interstellar medium when some of those stars grow old and explode.
Subsequent generations of stars therefore form from increasingly
metal-rich material.  Metal-poor stars, however, were formed from
the unpolluted environment that existed shortly after the Big Bang.
Exploring stars such as 2MASS J18082002-5104378 may unlock secrets
about their formation, and show what the Universe was like at its
very beginning.
GIGANTIC CLOUD RETURNS TO OUR GALAXY
Hubble Space Telescope astronomers are finding that the old adage
'what goes up must come down' applies even to an immense cloud of
hydrogen gas outside our Milky Way galaxy.  The invisible cloud is
plummeting toward our Galaxy at nearly 700,000 miles per hour.
Though hundreds of enormous, high-velocity gas clouds whizz round the
outskirts of our Galaxy, this so-called 'Smith Cloud' is unique
because its trajectory is well known.  New Hubble observations suggest
that it was launched from the outer regions of the Galactic disc
around 70 million years ago.  The cloud was discovered in the early
1960s by doctoral astronomy student Gail Smith, who detected the radio
waves emitted by its hydrogen.  The cloud is on a return collision
course and is expected to plough into the Milky Way's disc in about 30
million years.  Astronomers believe that, when it does, it will ignite
a spectacular burst of star formation, perhaps providing enough gas to
make 2 million stars.  Astronomers have measured the comet-shaped
region of gas to be 11,000 light-years long and 2,500 light-years
across.  If the cloud could be seen in visible light, it would span
the sky with an apparent diameter 30 times greater than the size of
the full Moon.  Astronomers long thought that the Smith Cloud might be
a failed, starless galaxy, or gas falling into the Milky Way from
intergalactic space.  If either of those possibilities were true, the
cloud would contain mainly hydrogen and helium, not the heavier
elements made by stars.  But if it came from within the Galaxy, it
would contain more of the heavier elements.
The team used Hubble to measure the Smith Cloud's chemical composition
for the first time They observed the ultraviolet light from the bright
cores of three active galaxies that reside billions of light-years
beyond the cloud.  Using Hubble's 'Cosmic Origins' spectrograph, they
looked at light that had passed through the cloud, in particular for
absorption lines of sulphur.  Sulphur is suggested to be a good gauge
of the abundance of heavier elements in general.  The astronomers
found that the Smith Cloud is as rich in sulphur as the Milky Way's
outer disc, a region about 40,000 light-years from the Galactic Centre
(about 15,000 light-years farther out than the Solar System).  That
means that the Smith Cloud was enriched by material from stars, which
would not have happened if it were pristine hydrogen from outside the
Galaxy, or if it were the remnant of a failed galaxy devoid of stars.
Instead, the cloud appears to have been ejected from within the Milky
Way and is now boomeranging back.  Though that seems to settle the
question of the Smith Cloud's origin, it raises new questions: how did
the cloud get to where it is now; what cataclysmic event could have
catapulted it from the Milky Way's disc; and how did it remain intact?
No answers are yet available.
'WOW!' SIGNAL THEORY
IFL Science
Almost 40 years ago, we received a mysterious signal from space.  The
signal lasted for 72 seconds and it was so unusual that it was dubbed
the Wow! Signal, owing to the word scrawled by its discoverer.  It has
been puzzling scientists ever since.  Several explanations from
unusual phenomena, transient events, and even aliens have been put
forward.  Now Paris, a professor of astronomy at St Petersburg College
in Florida, thinks that the signal might have originated from one or
two passing comets.  The objects were not known at the time, but their
orbit and position in 1977 was remarkably close to the location that
the Wow! signal seemed to have come from.  The Big Ear telescope in
Ohio, which made the original discovery, had a fixed field of view, so
it depended on the Earth's rotation to scan the sky; it could observe
any given area for only 72 seconds.  On 1977 August 15 it was looking
in the direction of the Chi Sagittari star group when it detected the
signal.  It was clearly of extra-terrestrial origin and definitely
worth follow-up observations.  The same region has been observed
several times since, but the observation has never been replicated.
For that reason, some researchers suggested that it was a one-off
event, something passing in the area of the sky at the time.  That
made Paris think of the comets 266P/Christensen and P/2008 Y2 (Gibbs).
The signal was observed at 1420 MHz.  The telescope used that fre-
quency to observe neutral hydrogen, which can emit at that wavelength.
Paris claims that the two comets release a lot of water and the UV
light from the Sun breaks the water, liberating the hydrogen.  Some
researchers are sceptical.  Comets would have to release a significant
amount of hydrogen to produce a signal as strong as the Wow! Signal.
The hypothesis must be tested before it is ruled out, and Paris will
get his chance in the next few years.  Comet 266P/Christensen will be
back in that region in 2017, and P/2008 Y2 (Gibbs) in 2018.  By
studying their radio emission and how quickly they move in the sky,
astronomers should be able to tell if either of them could really have
been the source of the Wow! signal.
JAMES WEBB SPACE TELESCOPE
BBC Science
The successor to the Hubble Space Telescope is reaching some key
milestones in its preparation for launch in 2018.  Engineers are about
to complete the assembly of the primary mirror surface on the James
Webb Space Telescope.  They are also finishing the final deep-chill
calibration tests on the observatory's four instruments.  The US
space-agency-led project is now on track to make rapid progress in the
coming months.  The major components of JWST, which have been years in
the design and fabrication phase, will at last be integrated into
their flight configuration.  With a time margin still in the programme
to cope with any unexpected problems, everything currently remains on
course for a 2018 October lift-off on a European Ariane rocket.  Webb
is a joint venture between NASA and its European and Canadian counter-
parts.  It will go in search of the very first stars to shine in the
Universe.  To achieve that ambition, it will deploy a 6.5-m mirror,
giving the observatory roughly seven times the light-collecting area
of Hubble.  And allied to instruments that are sensitive in the
infrared, Webb will be tuned to detect the faint, 'stretched' glow of
objects that originally shone more than 13.5 billion years ago.
SPACE MISSIONS FOR 2016
CosmosUp
2015 was the year we saw Pluto and found water on Mars.  In 2016, we
may be going to learn how the planets were made.  The European Space
Agency's ExoMars rover will land on Mars, Osiris-REX will be launched
towards the asteroid, and Rosetta will smash into comet 67P.  JAXA,
the Japanese Space Agency, is launching the X-ray telescope ASTRO-H
this month.  X-Rays are produced when cosmic matter is heated to
millions of degrees.  By looking at them from space, we can pick up
data impossible to gather from the ground.  The satellite has four
sensor systems, allowing it to measure hard and soft X-rays and gamma
rays, and to perform X-ray spectroscopy.  ASTRO-H will open up windows
into the distribution of dark matter in galaxies, and the large-scale
structure of the Universe.  Another mission this year is going to look
into the Solar System's formation as a whole by looking at Jupiter.
NASA's Juno spacecraft will arrive at the Jovian system on July 5.
Galileo was in orbit around Jupiter from 1995 to 2003, and we have not
had anything in orbit since.  We are long overdue for a dedicated
Jupiter mission, particularly one that will measure something we do
not know about -- the amount of water in Jupiter's atmosphere.  This
seems esoteric, but it is actually going to help scientists with the
major question of which planet-formation theory may be correct, or
tell us if we need an entirely new theory by telling us where the
water on Earth came from.  If Juno finds that there is little water in
Jupiter's atmosphere, scientists will probably conclude that icy
bodies like asteroids from the distant Kuiper Belt brought water as
ice to the rocky inner planets.  And because Jupiter is our best
example of a giant planet, knowing more about its formation may help
us understand the planets found around other stars.
ANTARCTIC FUNGI SURVIVE MARTIAN CONDITIONS
FECYT - Spanish Foundation for Science and Technology
European scientists have gathered tiny fungi that take shelter in
Antarctic rocks and sent them to the International Space Station.
After 18 months on board in conditions similar to those on Mars, more
than 60% of their cells remained intact, with stable DNA.  The results
provide new information for the search for life on Mars.  Lichens from
the Sierra de Gredos (Spain) and the Alps (Austria) also travelled
into space for the same experiment.  The McMurdo Dry Valleys, in the
Antarctic Victoria Land, are considered to be the most similar earthly
equivalent to Mars.  They make up one of the driest and most hostile
environments on our planet, where strong winds scour away even snow
and ice.  Only so-called crypto-endolithic micro-organisms, capable of
surviving in cracks in rocks, and certain lichens, can withstand such
harsh climatological conditions.  A few years ago a team of European
researchers travelled to those valleys to collect samples of two
species of crypto-endolithic fungi, Cryomyces antarcticus and
Cryomyces minteri.  The aim was to send them to the International
Space Station (ISS) for them to be subjected to Martian conditions and
space and to observe their responses.
The tiny fungi were placed in cells (1.4 cm in diameter) on a platform
for experiments known as EXPOSE-E, developed by the European Space
Agency to withstand extreme environments.  The platform was sent in
the Space Shuttle Atlantis to the ISS and placed outside the Columbus
module by an astronaut.  For 18 months half of the Antarctic fungi
were exposed to Mars-like conditions.  More specifically, that is an
atmosphere with 95% CO2, 1.6% argon, 0.15% oxygen, 2.7% nitrogen and
370 parts per million of H2O, and a pressure of 1,000 pascals.
Through optical filters, samples were subjected to ultra-violet
radiation as if on Mars and others to lower radiation, including
separate control samples.  The most relevant outcome was that more
than 60% of the cells of the endolithic communities studied remained
intact after 'exposure to Mars', or rather, the stability of their
cellular DNA was still high.
Re: Early February Astronomy Bulletin
« Reply #1 on: February 20, 2016, 21:34 »
The next one is going to be a beaut!
« Reply #2 on: February 20, 2016, 23:08 »
So they turn on this wave detector which they think is probably not up to the job, and a gravitational wave just happens to be passing at that very moment and the machine records it.  Serendipity at its best!   :o:
« Reply #3 on: February 21, 2016, 18:14 »
One could say its damaged the funding chances for further development... you can do it with that  - why do you need better!
« Reply #4 on: February 21, 2016, 20:25 »
Very good point Sam.  The big project is the e LISA orbiting satellite which is scheduled to be launched in 2034.  I would not be surprised if they cancelled it.
« Reply #5 on: February 25, 2016, 19:56 »
Indeed. By then all will be done on Earth!
« Reply #6 on: February 25, 2016, 22:05 »
Thy will be done on Earth as it is in heaven.  Where have I heard that line before?   ;D
« Reply #7 on: March 03, 2016, 18:59 »
Trump 2016 acceptance speech.
« Reply #8 on: March 03, 2016, 20:59 »
Gosh, don't!  That's getting scary!   :facepalm:
« Reply #9 on: March 03, 2016, 22:24 »
The whole world is getting scary!   :bawl:
« Reply #10 on: March 04, 2016, 19:10 »
Mate of mine posted this on Facebook:
"Post you don't want to be reading in 7 months time...........
'The American People cast their votes and said goodbye to the planet,
Off they went with the Trumpety Trump, Trump Trump Trump,
UK PM Boris was calling from far far away,
With Trump in charge and Boris at large it'll be World War 3 some day........."
« Reply #11 on: March 04, 2016, 19:31 »
 :clap:  Pretty good Sam.  The lunatics are running the asylum.   :devil:
« Reply #12 on: March 05, 2016, 19:24 »
Nothing new....
