Author Topic: Outlook Express 6  (Read 1304 times)
Outlook Express 6
« on: June 08, 2003, 18:59 »
Hi Folks only me  ;D
After some info, if anybody knows of any downloads to insert emoticons in the above e mail program I would be grateful for any links  ;D
Many thanks in advance  8)
Hookstar
Re:Outlook Express 6
« Reply #1 on: June 08, 2003, 19:52 »
There was something, but I can't remember what it was called!   ::)
All I do, Hookstar, is save all the ones I like in one folder.  You can soon built up a library, and if you want to use one in a e-mail, just use the Insert function.
In the meantime, I'll try to remember what the other thing was called.   ;D
« Reply #2 on: June 08, 2003, 19:59 »
There's this one, which is only a trial version, or this one, which is free, but quite old now.  Not tried either myself, so hopefully some more suggestions may be forthcoming.   ;)
