April 19, 2025, 03:29
Technical Help & Discussion
BIOS Questions?
Topic: BIOS Questions? (Read 3747 times)
bat69
Loyal Member
BIOS Questions?
November 22, 2002, 18:18 »
So you have a question about BIOS settings?
Go here for some very useful information
Re:BIOS Questions?
November 27, 2002, 20:51 »
Before I go ahead and break my PC, what will happen if I go into my BIOS and select the High Performance setting? Is there a way back? Can I just go back to the default settings if this goes pear shaped?
Thanks for the link Bat, but it's a bit over my head!! :'( :-[
Re:BIOS Questions?
November 27, 2002, 20:59 »
Dont worry Simon, the worst you can do is make your PC unstable. Popping back into the BIOS and selecting another setting will restore your PC back to health
Re:BIOS Questions?
November 27, 2002, 21:02 »
Thanks, Adept.
bat69
Loyal Member
Re:BIOS Questions?
November 27, 2002, 21:54 »
If you are going to tinker, find out what the settings are for, what they do and make a note of the original settings.
Then wherever possible, only change one setting at a time. If it becomes unstable then its much easier to trace which setting caused the trouble
Re:BIOS Questions?
November 27, 2002, 22:05 »
Well, all I was going to do was go into Soft Menu III Set Up and hit F7 for 'Optimum Settings', but I chickened out in the end! I thought as things seem to be running OK, and I don't know any different, I'll leave it be! :- :-[
Tony
Loyal Member
Re:BIOS Questions?
November 29, 2002, 00:45 »
be a devil Simon, hit that performance button, I've be running on the High performance Bios setting since last time we discussed it. Well over a week now and not so much as a hiccup, stable as a rock it is. Down to it being built with quality components, by a bespoke custom PC builder I suppose
Have you no faith in your work
Catch
Re:BIOS Questions?
November 29, 2002, 07:50 »
Hiya Catch,
What difference have you noticed since you went HP? I think my system runs sweetly as it is, so before I take the leap, I'd like to know what improvements to expect by hitting the High Performance setting.
Tony
Loyal Member
Re:BIOS Questions?
November 29, 2002, 15:37 »
Well to be honest Simon,
I have not run any bench test's as I have not got any bench test programes on my PC at the moment. And bench testing is the only way to compare default / HP setups when you think about it. But I assume it is faster and as it is stable I shall leave it on the HP setting.
Just try it will you, what are you a man or a mouse
worst that can happen is it crashes. And like Adept say's you can always reset it back to default performance setting. I don't know how you can resist trying it, or maybe you using your PC to control that new Ariane rocket
Re:BIOS Questions?
Reply #9 on:
November 29, 2002, 19:52 »
Well, I've done it, and I'm still here. It hasn't actually made any difference as far as I can tell. 8)
Re:BIOS Questions?
Reply #10 on:
November 29, 2002, 20:22 »
But isn't it satisfying to know that your PC is 0.001% faster Simon
Re:BIOS Questions?
Reply #11 on:
November 29, 2002, 22:29 »
It was satisfying enough when it switched on again!
daveeb
Loyal Member
Re:BIOS Questions?
Reply #12 on:
November 29, 2002, 22:45 »
i'm with you simon, if it works be thankful and leave well alone. yes we'd still be in caves if johnny caveman had thought like that, but it'd be a nice comfy familiar cave.
Tony
Loyal Member
Re:BIOS Questions?
Reply #13 on:
November 30, 2002, 17:08 »
Whoooooooooooooooosh there goes Super Simon folks >
catch
BIOS Questions?
