Author Topic: Downloading Windows Updates  (Read 1225 times)
Offline DJ
« on: June 09, 2003, 11:15 »
Hi All,
I've been downloading the windows updates as usual recently, but wondering where does windows store them once they have been downloaded.
The reason I ask is, I have two PC's - so rather than downloading them all twice (which is painful enough - but I'm on 28k!!!) - I'd rather download them once and then copy them to the other PC.
Is this possible??
Thanks
DJ1UK
Offline lobo
    • http://www.burnleywood.com
Re:Downloading Windows Updates
« Reply #1 on: June 09, 2003, 13:49 »
@DJ1UK
You will find the updates in the Windows folder i.e.
C:\WINDOWS\...............\Q329834$
The bad news is that all the updates are machine specific and self installing so its unlikely to be of any use to you.
Brian :-[
Homer   , The Odyssey, line 1
Offline DJ
« Reply #2 on: June 09, 2003, 16:35 »
Ok - Thanks for the reply.
I'll just have to download them twice then. Broadband is here at the end of the month - so I'll be much quicker then.
DJ1UK
