Author Topic: Incredimail  (Read 1582 times)
Offline Whiskas
Incredimail
« on: June 09, 2003, 13:29 »
Does anyone here use incredimail? I've had it for a while now and I just updated to the latest version. It was supposed to save all my addresses and emails which it did and was working fine for the past couple of days. I just noticed now that my key contacts are now missing, the addresses are still in my address book but if I add a new one to my contacts on the left hand side when I go back into incredimail later they have then disappeared ???
Re:Incredimail
« Reply #1 on: June 09, 2003, 13:39 »
I think Simon uses it Whiskas.
Re:Incredimail
« Reply #2 on: June 09, 2003, 13:46 »
I havent used it for a long time Whiskas,but I found this from an old thread :
Incredimail stores the info in the following directory
Incredimail | Data | Identities | {xxx strange number xxx} | Address  ..... or Messages
If you find that folder and then tell incredimail to import the address book from there it may sort your problem out  ???
Cant understand why it was ok at first though and messed up after a few days  ???
Re:Incredimail
« Reply #3 on: June 09, 2003, 20:06 »
I haven't used Incredimail for a while either.  There is a box to tick in the Properties of an address book entry to 'Add To Key Contacts'.  Maybe this is something to do with it?  You said that addresses added to your Key Contacts disappear - does the same happen when you add to your Address Book, Whiskas?
Offline Whiskas
Re:Incredimail
« Reply #4 on: June 10, 2003, 11:41 »
Well I don't know why it happened but it all seems to be fine now they have all reappeared by themselves ;D
Re:Incredimail
« Reply #5 on: June 10, 2003, 12:44 »
Thank for letting us know it had a happy ending Whiskas.
