November 27, 2024, 14:31
Technical Help & Discussion
Mobile Phones & Other Handheld Devices
Motorola Moto G4 16GB Dual SIM-Free Smartphone - White
4
5
9
Topic: Motorola Moto G4 16GB Dual SIM-Free Smartphone - White (Read 27657 times)
Re: Motorola Moto G4 16GB Dual SIM-Free Smartphone - White
Reply #30 on:
April 08, 2017, 11:00 »
I've taken out a contract with Tesco (O2) and the sim will be posted to me.
Reply #31 on:
April 08, 2017, 11:13 »
Reply #32 on:
April 08, 2017, 11:27 »
The case and screen protector has also turned up. Incredible value for £3.50.
Reply #33 on:
April 08, 2017, 11:35 »
Applying the screen protector without getting bubbles is a challenge!
Reply #34 on:
April 08, 2017, 12:36 »
The one I put on my Kindle Fire has started to peel off after 18 months. My phone case also contained a stylus for typing but it's very small. It's connected to a tiny plastic stub which presumably fits into a hole in the phone.
Reply #35 on:
April 08, 2017, 12:55 »
Not sure about that. If there's a hole in the phone, that's probably the earphones socket.
Reply #36 on:
April 08, 2017, 18:21 »
That would make sense. I must look at the instruction leaflet.
I was talking to a friend this afternoon who was telling me she doesn't bother paying for a data allowance because there are so many free hotspots available.
Reply #37 on:
April 08, 2017, 18:50 »
Depends where you are, I guess, and what the "free" hotspots want in return.
Reply #38 on:
April 08, 2017, 21:08 »
I shudder to think.
Reply #39 on:
April 12, 2017, 19:44 »
My sim turned up today and I'm good to go (apparently). To be fair I seem to have set it all up and in so doing proved that the Kodi box was faulty since the setup was eerily similar. I've downloaded a few free apps including a torch and added a few contacts. I've even sent an e-mail and tried out the camera. That's enough for today.
Reply #40 on:
April 12, 2017, 21:55 »
Reply #41 on:
April 12, 2017, 22:00 »
Even better, I've discovered that if I insert the sim card the correct way it will make a phone call!
Reply #42 on:
April 12, 2017, 23:35 »
Reply #43 on:
April 13, 2017, 09:43 »
Everything seemed to work OK until I tried to test the phone! I've downloaded a lot of apps although I suspect I might get rid of some of them. I've been told that WhatsApp is very useful. I'm considering buying a micro SD card to use with it.
Reply #44 on:
April 13, 2017, 11:14 »
WhatsApp is a messenger service. I don't use it, because I was worried about privacy, plus I don't want pinging every second of every day, all day long.
4
5
9
