Author Topic: The bitch test  (Read 3992 times)
The bitch test
« on: June 11, 2003, 06:40 »
Come on then Sandra.   ;D
Oh, it's not mandatory to give them an e-mail address.
http://test3.thespark.com/bitchtest/bitch.cgi
Re:The bitch test
« Reply #1 on: June 11, 2003, 13:12 »
See Clive I am not that bad at all really,I bet Serenity gets a lot higher bitch rating than me  ::)
The results are in. You are certifiably:
 44% bitch!
which is higher than the worldwide average 38%
How others compare:
  2% (same as you)
  32% (bitchier than you)
  66% (less bitchy than you)
I bet you thought I would be 50% after seeing my pic on the left  ;D ;D ;D
Re:The bitch test
« Reply #2 on: June 11, 2003, 13:13 »
We must demand that Serenity takes the test.   ;D
Re:The bitch test
« Reply #3 on: June 11, 2003, 13:27 »
I bet its the only test that shed get a higher mark than me in Clive  :slug:
Offline Serenity
Re:The bitch test
« Reply #4 on: June 11, 2003, 13:44 »
:dream:  SONDRA  :P  I am a nice gal me  ;D
37% bitch!
which is lower than the worldwide average 38%
so... conclusive proof that whoever gets to know me is a VERY fortunate person indeed  ;)  ;D   :heehee:
Offline Robotochan
Re:The bitch test
« Reply #5 on: June 11, 2003, 14:05 »
maybe you should take the test clive and see what you get and compare? It might turn out thatSandra is 43% Bitchier than yourself  :)
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:The bitch test
« Reply #6 on: June 11, 2003, 14:13 »
We need a "Wimp" test site for Clive Robo  ;D ;D ;D
Come on Simon get your finger out and make a :bitch: smiley for me and Serenity to use ;)
Re:The bitch test
« Reply #7 on: June 11, 2003, 17:41 »
There already is one, which was one of the originals used in Pals chatroom.  Perhaps Sean didn't include it in the current list because it might be overused!   ;D
Re:The bitch test
« Reply #8 on: June 11, 2003, 17:59 »
Oh the bitch test is for girls only Robotchan.   ;D  We guys are no good at bitching.   :lol:
Re:The bitch test
« Reply #9 on: June 11, 2003, 18:09 »
60% bitch!
How others compare:
  0% (same as you)
  7% (bitchier than you)
  93% (less bitchy than you)
 ;D had to tell little white lies here and there.. wrong colour lippy  8)
Offline Robotochan
Re:The bitch test
« Reply #10 on: June 11, 2003, 18:22 »
Theres an option for men pretending to be woman  ;)
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:The bitch test
« Reply #11 on: June 11, 2003, 18:42 »
Later!   ;D  I have to go out for a while but I'll be back.   :lol:
Re:The bitch test
« Reply #12 on: June 11, 2003, 19:19 »
Sorted! :-[ :bitch:
Re:The bitch test
« Reply #13 on: June 11, 2003, 19:56 »
Not only (hope Carling doesnt object  ::) ) is Pals probably the best forum in the world but we have the best bitches too  ;D ;D ;D
:bitch: :bitch: :bitch:
Re:The bitch test
« Reply #14 on: June 11, 2003, 23:08 »
 51% bitch!
How others compare:
  1% (same as you)
  17% (bitchier than you)
  82% (less bitchy than you
That settles it, I am Queen Bitch ;D ;D ;D
