Author Topic: Windows 10 Fall update  (Read 4258 times)
Offline Den
« on: October 18, 2017, 10:43 »
Hi all, Has anyone else updated today and how have you got on with this major update?
All seems well here and running very smooth indeed.  ;D
Re: Windows 10 Fall update
« Reply #1 on: October 18, 2017, 11:19 »
I've not noticed any difference, but I did have a huge update over the weekend, which resulted in an hour long reboot.   ::)
« Reply #2 on: October 18, 2017, 13:30 »
Mrs Clive's ancient Dell updated last night with no problems.
« Reply #3 on: October 18, 2017, 13:32 »
I don't seem to have it available for my own machine.
« Reply #4 on: October 18, 2017, 13:43 »
That's cause you only watch BBC.   ;D
« Reply #5 on: October 18, 2017, 16:40 »
Hadn't thought of that!   :thumb:
Offline Den
« Reply #6 on: October 18, 2017, 22:02 »
It only came out on Tuesday so yours sounds as if its the pre release that came out a couple of weeks ago. Just check the system file to see if you have been updated if you see version 1709 then you are there.  ;)
« Reply #7 on: October 18, 2017, 22:23 »
As long as it works, to be honest, I don't really care, Den.  I'd just quite like it if Windows 10 would occasionally give me some time on my own computer to do what I want to do, without it being slowed down by constant bloody updates.   >:(
Offline Den
« Reply #8 on: October 18, 2017, 22:39 »
Microsoft could turn into Apple and make your computer obsolete when they announce an update. :devil:
Offline Den
« Reply #9 on: October 19, 2017, 12:54 »
Just updated my laptop and all is well.  :D
« Reply #10 on: October 19, 2017, 13:25 »
Still 1703 No updates available.   :dunno:
Offline Den
« Reply #11 on: October 19, 2017, 16:48 »
You have to install 1703 before they let you move on to 1709. Try again it should be there by now (or perhaps mid/west Wales is out of bounds).  :D
Just for you Clive, don't tell Simon.  ;)
https://www.windowscentral.com/your-pc-getting-windows-10-fall-creators-update-date-here
« Last Edit: October 19, 2017, 17:17 by Den »
« Reply #12 on: October 19, 2017, 18:29 »
Don't do it, Clive!  It'll make you a smug git!   :devil:
« Reply #13 on: October 19, 2017, 20:03 »
