Author Topic: Aarrgh! Spring Updates threatened for Windows 10  (Read 9885 times)
Re: Aarrgh! Spring Updates threatened for Windows 10
« Reply #30 on: April 29, 2018, 09:57 »
Love it Gill!   :thumb:
Offline Den
« Reply #31 on: April 30, 2018, 21:57 »
Just updated my main computer               "WOW"      But then again I love change and improvements.  ;D
Online Simon
« Reply #32 on: April 30, 2018, 22:17 »
Mine seems to have behaved itself for the most part tonight, so hopefully my delay setting has worked.  :)
Offline Den
« Reply #33 on: April 30, 2018, 22:21 »
The changes seem really good indeed. Just a gentle learning curve.  8-)
« Reply #34 on: April 30, 2018, 22:40 »
Mine went into a "critical crash" this morning and had to be restarted after it sent lots of data to Microsoft.  Presumably blocking the update has worked.   :thumb:
Online Simon
« Reply #35 on: April 30, 2018, 22:46 »
But now they know what you've done!   :nerves:
« Reply #36 on: May 01, 2018, 03:37 »
I'm using a tablet. The PC isn't being switched on for at least another 48 hours. By then, enough time should have elapsed for the major defects to have come to light.
« Reply #37 on: May 01, 2018, 10:35 »
and this is supposedly progress  :ack:
i've jumped through hoops to keep MrsDaveeb's win 10 pc update free, but despite my best efforts it looks like it started last night....She was alerted to the fact that something was happening because her wifi got turned off by windows  >:( >:(  and sure enough there's a mile long queue of stuff that WILL install whether she likes it or not.
Online Simon
« Reply #38 on: May 01, 2018, 11:59 »
I think I'll just turn my Windows 10 laptop on, leave it in a cupboard for 48 hours, and just let it get on with it.   :bawl:
« Reply #39 on: May 01, 2018, 16:13 »
No more mishaps with mine.  And no updates.   :thumb:  Mrs Clive is delighted that I've connected her iPad to the printer network and it now prints out both sides of a sheet of paper.  Not quite sure I deserve the credit but I will gladly accept it.   ;D
Online Simon
« Reply #40 on: May 01, 2018, 16:14 »
Take it while you can get it!   ;D
« Reply #41 on: May 01, 2018, 16:26 »
It won't last long.   ;D
Offline Den
« Reply #42 on: May 01, 2018, 19:50 »
Right now I am updating my laptop, will report back later.  :D
« Reply #43 on: May 01, 2018, 20:16 »
For you Den, there may be no later.   :facepalm:
Offline Den
« Reply #44 on: May 01, 2018, 21:10 »
Do you know something that I'm not aware of Clive?    77% installed and counting.  :D
