April 30, 2025, 06:25
Technical Help & Discussion
Aarrgh! Spring Updates threatened for Windows 10
4
Topic: Aarrgh! Spring Updates threatened for Windows 10 (Read 10869 times)
Re: Aarrgh! Spring Updates threatened for Windows 10
Reply #45 on:
May 01, 2018, 22:03 »
That's probably as far as it gets Den. They usually blow up at 80%.
Den
Reply #46 on:
May 02, 2018, 07:54 »
Completed
Reply #47 on:
May 02, 2018, 08:19 »
Phew! I'll bet that's a relief.
Den
Reply #48 on:
May 02, 2018, 15:06 »
Never doubted it.
Den
Reply #49 on:
May 05, 2018, 09:29 »
Is it just me? The April update loaded onto my two computers and are superb. Task View is such a good addition and the whole update runs so well.
Reply #50 on:
May 05, 2018, 10:10 »
I'm sure there is a built in time delay before your computer goes into meltdown Den.
Den
Reply #51 on:
May 05, 2018, 14:30 »
They are running very smoothly at the moment, well pleased.
Reply #52 on:
May 05, 2018, 20:23 »
4
