Author Topic: ASP Problem  (Read 1622 times)
Offline Eagle
    • http://www.eagleseye.co.uk
ASP Problem
« on: June 15, 2003, 19:12 »
Can anyone help me out?
I get this message (below) trying to access a Web Site. I have tried searching the Web for an answer, but they say it all in Technospeke, so cannot understand it. I can't even find the file mentioned on the Hards disk.
How do I get out of this one? I am using Windows 2000.
Cheers,
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Unable to load file 'LMUDOTVB'.
Source Error:
Line 197:                <add assembly="System.Drawing, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/>
Line 198:                <add assembly="System.EnterpriseServices, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/>
Line 199:                <add assembly="*"/>
Line 200:            </assemblies>
Line 201:
Source File: c:\winnt\microsoft.net\framework\v1.0.3705\Config\machine.config    Line: 199
Version Information: Microsoft .NET Framework Version:1.0.3705.288; ASP.NET Version:1.0.3705.288
Re:ASP Problem
« Reply #1 on: June 15, 2003, 19:18 »
OMG look what the cat just dragged in.  ;D  Someone (not me as you well know) will come up with an answer soon me old matey.
Re:ASP Problem
« Reply #2 on: June 15, 2003, 19:32 »
Hi Eagleseye! Long time no hear ;)
I'm not 100% sure but it seems to be a problem with the actual web server.
Could you post the URL so that I can test for you whether it works?
I often see ASP errors on certain web sites. This is because I use the Opera browser rather than Microsoft's Internet Exploder ::)
Offline Eagle
Re:ASP Problem
« Reply #3 on: June 15, 2003, 19:53 »
Cheers Sean,
I will try it again later and see if they have resolved their problems then. I thought it was me as I had been tweaking my system today and thought I may have tweaked that little bit too much.
Re:ASP Problem
« Reply #4 on: June 15, 2003, 19:55 »
Story of your life Dave.   :heehee:
