Author Topic: Adobe Premier Video Editor  (Read 1650 times)
« on: October 08, 2018, 15:32 »
My Adobe Premier Video Editor won't load.  It gets  a little way into the load-up screen then crashes at the same point.  I've uninstalled and re-installed but to no avail.  OS is Windows 10.
Any ideas?
Re: Adobe Premier Video Editor
« Reply #1 on: October 08, 2018, 16:05 »
Maybe it's averse to a recent Windows Update, or perhaps the program itself requires an update?  It's possible that WU has updated some drivers that the program doesn't like.  This may help:
https://forums.adobe.com/thread/2438127
« Reply #2 on: October 08, 2018, 18:19 »
Thanks, Simon, I'll look into that  :)
« Reply #3 on: October 09, 2018, 20:30 »
The advice you gave on this thread https://www.pc-pals.com/smf/index.php/topic,44209.0.html also sorted out my problems with Adobe Premier  :)
