Author Topic: Unable To Save Work  (Read 2185 times)
Unable To Save Work
« on: October 09, 2018, 15:27 »
Whenever I try to save my work from any program from any program, I get this error message:
I can save to USB sticks, then cut and paste into the directory where I had originally wanted to save my work.  Can anyone please help me understand what might be going on?
Re: Unable To Save Work
« Reply #1 on: October 09, 2018, 16:05 »
Have you accidentally made the file read only Gill?
« Reply #2 on: October 09, 2018, 16:07 »
Nope. It's like that with all programs and all files.  I've checked the user privileges but they're okay - all users have permission to write and alter files.
« Reply #3 on: October 09, 2018, 17:09 »
Is this following a Windows 10 update?  Have you tried restarting the machine?
« Reply #4 on: October 09, 2018, 19:21 »
It's not after an update and I have rebooted the machine several times.
« Reply #5 on: October 09, 2018, 19:55 »
It seems there may be an issue with Windows Defender:
https://forums.adobe.com/thread/2404224
« Reply #6 on: October 09, 2018, 20:22 »
Many thanks, Simon - it was the Controlled Folder Access setting that was affecting my PC too.  Once again, many thanks  :thumb:.
 :thanks: :welldone:
« Reply #7 on: October 09, 2018, 21:16 »
:ithank:
