Author Topic: keyboard configuration  (Read 884 times)
« on: June 19, 2003, 01:35 »
My friends keyboard's @comes up" and vice verca. I think there is a way of changing it back to normal keyboard setting but I don't know how to do it.  Any advice? :)
Re:keyboard configuration
« Reply #1 on: June 19, 2003, 01:48 »
Its set to the default USA English Lona.
Just go to Control Panel and open Regional and Language options.
It will be in advanced on XP (I think you said she was on XP the other night)delete the US English and add English UK,it will say it cant do it until next time it restarts so just reboot and it should be sorted  :-*
« Reply #2 on: June 19, 2003, 01:55 »
Thanks for the prompt reply, I knew I could rely on you.  Wish I had not wasted all that time today trying to figure it out by myself. Thanks again :-*
