Author Topic: Printer Question.  (Read 921 times)
Offline twiggy
Printer Question.
« on: June 19, 2003, 14:19 »
I dont no if anyone would no the answer to this but if you could give me a few answers to try and correct it. I have a hewlett packard deskjet 970Cxi. Now when ever i try and print something i keep getting this error message:
Error writing to LPT1: for Document xxxxxxxxx: This operation returned because the timeout period expired.
Do you wish to retry or cancel the job?
When ever i click retry it comes back with the same answer. All leads are in and linked. Any ideas?
Thanks Mark.
Re:Printer Question.
« Reply #1 on: June 19, 2003, 14:25 »
Does it print a test page ok or does that time out too Mark?
If you go to Control Panel then right click on Printer then Properties it should give you an option to print a test page.
Also got Device Manager and see if there is a yellow ? or ! next to it,that would probably indicate that the printer drivers needed re installing  :-*
Offline twiggy
« Reply #2 on: June 19, 2003, 14:54 »
Its ok now problem solved. The black cartiage was clogged so replaced it and its working fine now. Thanks any way.
Mark
« Reply #3 on: June 19, 2003, 15:01 »
Glad to hear it Mark,hope we sort the RAM query out soon  :-*
