Author Topic: Smart TV problem  (Read 7924 times)
Re: Smart TV problem
« Reply #15 on: January 04, 2020, 19:19 »
I won't even drive across the Humber bridge, such is my dislike of heights.  You have my every sympathy for not erecting your new TV aerial.
Before Christmas I found myself appointed as the local Silver Band's official photographer.  In order to photograph them without getting the back of the audience's heads in the shot, I have to climb a pair of step ladders to get a higher vantage point.  Even that gives me the collywobbles.
 :nerves:
« Reply #16 on: January 04, 2020, 19:22 »
It's funny, whenever I hear if somebody fitting an aerial, I always think of Rod Hull, and the Emu popping up out of the chimney and knocking him off the roof!
« Reply #17 on: January 04, 2020, 20:38 »
I'm enjoying the high pressure, since our local TV transmissions were modified (part of the 5g rollout) I haven't been able to get my favourite channel BBC4 HD because they now transmit it from a low power transmitter instead of the one they used to use. High pressure seems to be be the most favourable condition for it to magically reappear.
I have bought a new wideband aerial which I did plan to put on the roof instead of our current loft aerial, however I then remembered Rod Hull and decided against the roof idea.  :crazy:
I wondered what became of BBC4HD.  We lost ours over 6 months ago.
« Reply #18 on: January 05, 2020, 00:09 »
I've never had BBC4 HD!   :bawl:
« Reply #19 on: January 05, 2020, 01:38 »
Could this be a conspiracy to get everyone to sign up to Britbox?
 :crazy:
« Reply #20 on: January 05, 2020, 10:07 »
That wouldn't surprise me.
« Reply #21 on: January 05, 2020, 11:33 »
What a cynic you are Gill!   ;D
« Reply #22 on: January 05, 2020, 19:25 »
 :nerves:
You need a drone.
« Reply #23 on: January 05, 2020, 19:26 »
We get it via Virgin... you know Fibre optics... or do we not get that outside of cities????  o:)
« Reply #24 on: January 05, 2020, 20:50 »
We do, but I haven't.  Don't really see the need when my internet usually works fine as it is.
« Reply #25 on: January 06, 2020, 19:20 »
No fibre? Strange.
« Reply #26 on: January 06, 2020, 19:22 »
Websites usually work fine, downloads are fast, and streaming TV is no problem.  Why pay the extra for fibre?
« Reply #27 on: January 07, 2020, 19:55 »
I think its likely cheaper here....  :dunno:
Offline pctech
« Reply #28 on: August 16, 2020, 16:20 »
Sorry to be severly late to the party on this, had a similar issue with a Samsung 2018 model TV which just suddenly wouldn't connect with the Wi-Fi even there is literally one wall between it and my router which is the hallway, I ended up forgetting and rejoining it to the Wi-fi, all good since but this has probably been done.
Mitch
« Reply #29 on: August 16, 2020, 16:38 »
I tried that with my errant Samsung but it still refused to connect.
