Author Topic: Speakers and Headsets  (Read 1971 times)
Offline Big_Boss
« on: November 24, 2002, 20:10 »
Hi,
I have a problem. Well its not really a problem more a niggle. Yesterday i went and bought a headset with a microphone built onto it so i can use it during games. It works fine but when i want to use it i have to take the connection out of the back of the speakers and plug the headset in.
Is there a connector that allows you to connect both the speaker and the headset to the back of the sound card at the same time?
Advice would be appreciated,
Big_Boss
Re:Speakers and Headsets
« Reply #1 on: November 24, 2002, 20:28 »
It's not an ideal solution, but you can pick up a 3.5 stereo socket doubler from most electrical outlets.
The only problem with these is they don't cancel the speakers when you use headphones and vice versa.
A better solution is the speaker systems that include a headphone and microphone socket. Unfortunately it seems to be the lesser quality speakers that include this facility  :(
