Author Topic: Do I need to go to the opticians???  (Read 2749 times)
Offline Whiskas
« on: November 24, 2002, 20:15 »
Is it me or does the background on the index page keep changing? sometimes it has the moon and other times it has purple lines ??? perhaps I need to get some glasses ;D
Offline Big_Boss
Re:Do I need to go to the opticians???
« Reply #1 on: November 24, 2002, 20:17 »
Havent noticed anything myself, but maybe thats a sign that I need to go to get glasses.  ;D ;D
Big_Boss
« Reply #2 on: November 24, 2002, 20:21 »
Sounds as if you need a degauss Whiskas.  There should be a degauss button on your monitor.  Otherewise just try a reboot but make sure the monitor switches right off.
« Reply #3 on: November 24, 2002, 20:22 »
It doesn't change for me Whiskas. It's always a really jaggy piccy of the moon.
(Note to self - find a better picture  ;D)
Anyone else having this problem?
Offline Whiskas
« Reply #4 on: November 24, 2002, 20:24 »
I dont have Degauss for some reason. My screen is funny any way it is slightly out of shape but I cant seem to put it right :'( I'll try rebooting thanks Clive ;D
« Reply #5 on: November 25, 2002, 03:51 »
The symptoms dont seem to point to needing to degauss as thats usually patchy areas of discolouration on the screen.
Dont worry if you havent got a degauss button as all TVs and Monitors have a degaussing circuit built in.
This degausses it on switching on,so if you think you have a problem just switching the monitor on and off will degauss it  :-*
As its not a web page fault,should this be moved to hardware  ???
