November 27, 2024, 19:42
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
e-mail problems
Topic: e-mail problems (Read 4180 times)
Camstop
Loyal Member
e-mail problems
November 26, 2002, 11:45 »
hi all
i just installed win98se and i am using fast24 and incredimail.
i don't think that i have my accounts set up properly.
what is fast24 pop3 and smtp addresses, i seem to have misplaced them in the overhaul
bat69
Loyal Member
Re:e-mail problems
November 26, 2002, 12:54 »
Hi Camstop,
Have you used Outlook Express etc, before with Fast24? if so, IncrediMail can import the settings from those applications.
Other than that, I don't know what Fast settings are, sorry :-";"xx
Sandra
Ultimate Member
Re:e-mail problems
November 26, 2002, 13:47 »
Here are the Pop3 and Smtp settings Camstop
POP3.fast24.net
SMTP.fast24.net
Camstop
Loyal Member
Re:e-mail problems
November 26, 2002, 15:41 »
hi sandra
got that ok.
can u give me a clue to what my user name might be, or the second half of it at least.
Sandra
Ultimate Member
Re:e-mail problems
November 26, 2002, 16:12 »
The only info I have on it Camstop is that its the same username and password (as your log in name I assume )
Its something I got from someone on Fast when a friend lost his details and luckily I kept that much as a notepad doc.
I havent a single contacts fast24 address,they all seem to use an alternate one
Just got this off Fast24 site :
A Fast24 email address (yourlogin@fast24.co.uk).
Hope that helps
Camstop
Loyal Member
Re:e-mail problems
November 26, 2002, 16:58 »
thanks sandra
just getting my .net and .co.uk mixed up. :-[
Sandra
Ultimate Member
Re:e-mail problems
November 26, 2002, 17:02 »
Easily done,I thought it was .net before I looked on the site
If it still doesnt work try .net as I am sure I have seen some with that ending on fast ones
Camstop
Loyal Member
Re:e-mail problems
December 01, 2002, 21:44 »
hi all
it's me again
can get my fast24 e-mails but i can't get my mail from my domain addresses.
i think i may have the wrong user-name in the servers page and i cant remember what you put in around your e-mail address
is anyone on fast24 with a domain e-mail address that can give me a clue?
Re:e-mail problems
December 01, 2002, 21:53 »
Well, I'm guessing here, Camstop, but it would probably be <anything>@yourdomain.fast24.co.uk
Camstop
Loyal Member
Re:e-mail problems
Reply #9 on:
December 01, 2002, 22:07 »
cheers simon
how did you know
no problem, i got the name i was looking for. postmaster
Re:e-mail problems
Reply #10 on:
December 01, 2002, 22:28 »
Well, it's a fairly standard format for domain e-mail addresses, Camstop. The part before the '@' can usually be whatever you like, so you probably don't have to stick to 'postmaster' if you want something different. It's the bit following the '@' which is more important.
e-mail problems
