Author Topic: Sound Bar  (Read 4346 times)
Sound Bar
« on: April 19, 2022, 18:54 »
I've just installed a Hisense soundbar recommended by ComputerActive.  The cost was a mere £79 and I have to say it's a gamechanger.  Your TV really has to have an HDMI ARC socket otherwise you will have to connect by bluetooth or optical.  I'm quite taken aback by the quality and sound separation.   :thumb:
Online Simon
Re: Sound Bar
« Reply #1 on: April 19, 2022, 19:51 »
I've often looked at them, as a possible space saving exercise, but my current TV has quite a wide pedestal, so there wouldn't be room for a soundbar underneath the screen, and it's pointless having it anywhere else.  When I eventually buy a new TV, I would look at one with the sound built into the screen, as they're supposed to be quite good.  Nothing beats a proper home cinema audio system though, so I don't think I will be giving mine up for a while yet.
Re: Sound Bar
« Reply #2 on: April 19, 2022, 20:57 »
If it ain't broke don't fix it.   :)
Online Simon
Re: Sound Bar
« Reply #3 on: April 19, 2022, 21:00 »
Indeed!   8-)
