July 03, 2024, 07:06
Technical Help & Discussion
Nice n Cool
Topic: Nice n Cool (Read 1479 times)
TR
Nice n Cool
July 02, 2003, 19:00 »
HI folks.. 8)
Gave the Puter a bit of a birthday last night and what a result
The CPU was running a tad hot (57c) so had a look inside and found the heat sink clogged right up with dust, so out with the can of air.. a few blasts big cloud of dust 1 or 3 spiders ran about
Switched back on and now running a super cool 47c its suprising how much the dust makes the CPU run hot.. so a lesson learned there every 3 months clean out heat sink
Hookstar
Sandra
Ultimate Member
Re:Nice n Cool
July 02, 2003, 19:34 »
A word of warning to anyone using air to blow dust and things around inside your PC,sometines the dust can get on the lenses of your cd rom and writers.
So if you have problems with not reading cds or burning them run a lens cleaner on your drives
bat69
Loyal Member
Re:Nice n Cool
July 04, 2003, 17:11 »
A nice little tip is to have your vacuum going and have the long hose thinggy near to where you're blowing the dust to suck it up.
Careful you don't touch anything with it though.
And don't use it in place of sheep Clive
Re:Nice n Cool
July 04, 2003, 18:50 »
I have a 1" paintbrush [unused
] which I use to lightly brush the dust off components into the suction of the vacuum cleaner. It is especially useful for keeping the blades of fans dust free.
As Bat says, you have to be careful not to touch anything you shouldn't and you should also be careful not to damage any components.
Re:Nice n Cool
July 04, 2003, 20:38 »
So, in reality, for a 'normal' home user, using their PC for, say, 5-6 hours per day, how often should you need to go in and do the dusting?
Re:Nice n Cool
July 04, 2003, 20:41 »
There's no such thing as normal Simon
Open up the case once a month. If you can write your name in the dust settled at the bottom of the case - it needs cleaning
Re:Nice n Cool
July 04, 2003, 20:48 »
Once a month!!! I haven't opened my case since I built the thing!
Re:Nice n Cool
July 04, 2003, 22:40 »
A very wise decision if I might add Simon.
After all, you wouldn't want to disturb that hamster you lost 6 months ago. :heehee:
Nice n Cool
