Author Topic: PC Protection  (Read 6647 times)
Offline mafunga
  • New Registration
PC Protection
« on: July 09, 2003, 09:16 »
How best can I protect my PC that is in the form of locking it. I use an open office where everyone has access to my PC, so what i need to do is to lock my profile. If you know how best I can do it please help me.
ndy Celes Mafunga
Chinhoyi University of Technology
P Bag 7724
Chinhoyi
Zimbabwe
263-67-22203/7 ext Library
Zimbabwe
09263
Tel 263-67-22203/7
Re:PC Protection
« Reply #1 on: July 09, 2003, 09:41 »
Hi Mafunga, and welcome to PC Pals.
Can you tell us what operating system you are using?  If you have XP, it may be as simple as creating passwords for different user profiles.
Offline DJ
Re:PC Protection
« Reply #2 on: July 09, 2003, 10:43 »
If its NT it's usually a case of CTRL + ALT + DEL and 'lock workstation'.
Of course if your IT people haven't sorted log on ID's and Passwords it's going to be difficult to lock the PC in the first place  ;)
DJ1UK
Offline Robotochan
Re:PC Protection
« Reply #3 on: July 09, 2003, 11:03 »
You can do what DJ1UK said with 2000 too :)
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline bat69
Re:PC Protection
« Reply #4 on: July 10, 2003, 00:15 »
Unfortunately if you have Win 98 you will need some third party software as the security on that is pretty useless.
Offline lobo
    • http://www.burnleywood.com
Re:PC Protection
« Reply #5 on: July 10, 2003, 17:33 »
@mafunga
You can set a password protected screen saver that will not allow other users to access the PC when you are away from the PC, (they can always switch of the powere and reboot but then they would not have access to the work you were doing Right on the screen area, select properties from the dropdown menu and then select screen saver, select a screensaver and click on settings and set a password for the screen saver, set time to 1min and if you leave the PC for more than 1 min the screen saver becomes active and can only be canceled by entering your password
Brian ;D
Homer   , The Odyssey, line 1
Re:PC Protection
« Reply #6 on: July 10, 2003, 17:58 »
That's a good tip, Brian.  I used to have a screen saver control that sat in the system tray, so you could just click it to immediately activate your screensaver, or right click it for other options, such as turning it off when defragging.  Somehow I lost it when I built my new PC, and I don't even know what it was called now.  Does anyone know of a similar prog?  Preferably free.   ;D
Offline lobo
Re:PC Protection
« Reply #7 on: July 10, 2003, 18:23 »
From my own personal store my friend, its a sharware file but no time limit on it
https://www.trustclip.com/2MDM8H075G06TeFOVO23GUOQ19K
Brian ;D
Re:PC Protection
« Reply #8 on: July 10, 2003, 18:29 »
To add a screensaver to the Quicklaunch Toolbar:
Start > Find > *.scr
Right-click one and choose Copy
Right-click Desktop and choose Paste
Drag to Quicklaunch Toolbar
Re:PC Protection
« Reply #9 on: July 10, 2003, 19:00 »
I'll try that - thanks Brian!
Dave, thanks mate, but that wouldn't really achieve what I was looking for, although it's a nice idea if you just want a quick launch for your screensaver.  The program I had before used to control them all, and had other functions as well.   :)
Re:PC Protection
« Reply #10 on: July 10, 2003, 21:48 »
I know the type of Program, Simon, but I haven't come across anything like that for a long time.  I used to have one, but that was in the Windows point something or other For Workgroups days.  I still have some old software on disk from those days, so I'll have a look tomorrow and see if I still have it.  Don't know if it would work with a later OS though.
Offline lobo
Re:PC Protection
« Reply #11 on: July 10, 2003, 21:59 »
@chorleydave That program of mine just sits in the toolbar click on it enter a password and it activates the screen server and wont close until you re-enter the pass, you can set a different password every tome
Brian ;D
Re:PC Protection
« Reply #12 on: July 10, 2003, 22:03 »
That sounds like a good program, Brian.   I've also found this one on CNET:
http://download.com.com/3000-2409-10148886.html?tag=lst-0-3
Re:PC Protection
« Reply #13 on: July 10, 2003, 23:25 »
That's quite a good one Dave.  I think I might give that one a try.   :D
Brian, thanks also for yours, although I wasn't quite expecting it to do what it did, and it scared me half to death, as I hadn't put a password in!  After a small moment of sheer panic, I just left it blank and clicked Enter and all was well.   ;D
Offline lobo
Re:PC Protection
« Reply #14 on: July 10, 2003, 23:38 »
Nothing like a bit of panic to make the day go faster
Brian :sanity:
