November 27, 2024, 23:44
Technical Help & Discussion
Where'd My Text Go Then?
Topic: Where'd My Text Go Then? (Read 2143 times)
Robotochan
Established Member
July 12, 2003, 17:31 »
I need a wee bitty of help. Since I installed Ultima Online, every day after a lot of loading or playing UO for more than 30 mins all the text on my screen vanishes such as menus, websites and MSN messenger, any help on sorting this dastardly fiend?
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Where'd My Text Go Then?
July 12, 2003, 18:44 »
I nothing about Ultima, so I'm only guessing here, but it sounds as if there may be some kind of graphics problem related to UO.
I assume you are up-to-date with any patches that have been released for it etc. It's also worth using DXDIAG to check that there's nothing wrong with DirectX on your machine.
Robotochan
Established Member
July 12, 2003, 19:24 »
DXDIAG said everything was ok, however the last screen said it needed at least Direct X 8 installed and I have 8.1
b]Oxymoron: [/b]
Example:
Microsoft Works
July 12, 2003, 20:52 »
Isn't there a Direct X 9 out now? Maybe updating might help? Just a guess.
If you want to, you can get it
<<here>>
Sandra
Ultimate Member
July 12, 2003, 21:03 »
Try looking for a driver update for your graphics card Robo.
Greenking was having a similar problem and he got that message when he had direct x ver.9 installed and it couldnt find it on his PC,not sure if he got it sorted but I think that was his error message
Robotochan
Established Member
July 12, 2003, 22:06 »
Theres been no updates for my TNT2 with the last 3 detonator driver updates
b]Oxymoron: [/b]
Example:
Microsoft Works
Robotochan
Established Member
July 13, 2003, 11:18 »
I just loaded up Flash MX and my words have gone again. It was fine with Flash 5. Any ideas now?
b]Oxymoron: [/b]
Example:
Microsoft Works
