Author Topic: Ace Mega Codec Pack  (Read 2536 times)
Ace Mega Codec Pack
« on: July 13, 2003, 18:39 »
Hello dears,
   Not knowing what it is as a program, I wanted - by curiousity to install "Ace Mega Codec Pack 5.91". After a while I removed it. I noticed that "Windows Media player" and "RealOne Player" don't work any more. So, I reinstalled them again. Only "Windows Media Player" works but not the other. I reinstalled "Ace Mega..." it did not help. Still "RealOne Player" doesn't work.
   Any Idea?
   And can you please, if you know all the advantages of this "Ace Mega..." tell me if it's worthy to use and keep it? Because it has also "Antivirus system and other things.
                            Thank you.
Offline lobo
    • http://www.burnleywood.com
Re:Ace Mega Codec Pack
« Reply #1 on: July 13, 2003, 21:46 »
@Joudi
In most situations, you do not need to install codec/filter packs and certainly not every codec/filter that comes with these packs. In fact, you may run into problems if you install too many codec/filters on your computer. It is Highly recommended that you only install the codec/filters that you absolutely need.
Thes packs contain codec and drivers that replace windows codec and drivers and when you removed them you dod not replace the windows codecs or drivers
CONTENTS
This pack contain lot of CoDeceS and ActiveX FilterS (for Media Player based players). There are some Flag after the components name, here is the description:
ProXP - component of ProXP version
PlayerXP - component of PlayerXP version
Not Installed as Typical - Not install as Typical mode you can only install in Custom mode
Every PlayerXP component included in ProXP. Compact mode of ProXP equal PlayerXP Typical mode.
ActiveX Filters
AC3 Decoder ActiveX Filter (ProXP,PlayerXP)
AC3/MP3 File Source ActiveX Filter (ProXP,PlayerXP)
Bicubic Resizer (ProXP,PlayerXP)
CyberLink Audio ActiveX Filter (ProXP,PlayerXP)
CyberLink Audio Effect ActiveX Filter (ProXP,PlayerXP)
CyberLink DVD Navigation ActiveX Filter (ProXP,PlayerXP)
CyberLink Video/SP ActiveX Filter (ProXP,PlayerXP)
Darim Vision MPEG-1/2 Decoder ActiveX Filter (ProXP,Not Installed as Typical)
DeDynamic ActiveX Filter (ProXP,PlayerXP)
Direct VobSub (ProXP,PlayerXP)
DirectShow Filter Enumerator (ProXP,PlayerXP)
DirectSound 3D Renderer ActiveX Filter (ProXP,PlayerXP)
DivX 3.2 (ProXP,PlayerXP)
DivX 4.12 (ProXP,PlayerXP)
DivX AntiFreeze ActiveX Filter (ProXP,PlayerXP)
DivX scene-detect patch (ProXP,PlayerXP)
DivXG400 (ProXP,PlayerXP,Not Installed as Typical)
DPS Media Conversion (DPS2AVI) (ProXP)
Elecard Async sample ActiveX Filter (ProXP,PlayerXP)
Elecard MPEG2 Demultiplexor ActiveX Filter (ProXP,PlayerXP)
Elecard MPEG2 Stream Demultiplexer ActiveX Filter (ProXP,PlayerXP)
Elecard MPEG2 Trimmer ActiveX Filter (ProXP,PlayerXP)
Elecard MPEG2 Video Decoder ActiveX Filter (ProXP,Not Installed as Typical)
Elecard PIM2 Null ActiveX Filter (ProXP,PlayerXP)
Elecard Sync2Async ActiveX Filter (ProXP,PlayerXP)
File Dump ActiveX Filter (ProXP,PlayerXP)
FullMotionVideo Decoder (ProXP)
I-Media AVI Renderer ActiveX Filter (ProXP,PlayerXP)
I-Media Multi-MPEG2-Source ActiveX Filter (ProXP,PlayerXP)
Intel Indeo Audio ActiveX Filter (ProXP,PlayerXP)
Intel Indeo Video 4.5 ActiveX Filter (ProXP,PlayerXP)
InterVideo Audio Decoder ActiveX Filter (ProXP,PlayerXP)
LAME MPEG Layer III Audio Encoder Filter (ProXP,PlayerXP)
Ligos MPEG Audio Decoder ActiveX Filter (ProXP,PlayerXP)
Ligos MPEG Video Decoder ActiveX Filter (ProXP,PlayerXP)
Ligos MPEG-2 Parser ActiveX Filter (ProXP,PlayerXP)
Ligos MPEG-2 Splitter ActiveX Filter (ProXP,PlayerXP)
Microsoft H.263 CoDec ActiveX Filter (ProXP,PlayerXP)
Microsoft H261 CoDec ActiveX Filter (ProXP,PlayerXP)
Microsoft MPEG4 Video Decompressor ActiveX Filter (ProXP,PlayerXP)
Microsoft Screen Video Decompressor ActiveX Filter (ProXP,PlayerXP)
Microsoft Windows Media Audio (ProXP,PlayerXP)
Microsoft Windows Media Audio Decoder ActiveX Filter (ProXP,PlayerXP)
Microsoft Windows Media Video Decoder 8 ActiveX Filter (ProXP,PlayerXP)
Microsoft Windows Media Video Decoder ActiveX Filter (ProXP,PlayerXP)
Moonlight DumpPos ActiveX Filter (ProXP,PlayerXP)
Moonlight MPEG2 Multiplexer ActiveX Filter (ProXP,PlayerXP)
Moonlight Odio Dekoda DirectShow Filter (ProXP,Not Installed as Typical)
Moonlight WinDivX (ProXP,Not Installed as Typical)
Morgan Multimedia MJPEG (ProXP,PlayerXP)
Morgan Multimedia Stream Switcher ActiveX Filter (ProXP,PlayerXP)
MPEG Layer 2 Audio Decoder ActiveX Filter (ProXP,PlayerXP)
MPEG Layer 3 Decoder ActiveX Filter (ProXP,PlayerXP)
MPEG-2 Splitter AC3 ActiveX Filter (ProXP,PlayerXP)
NetPlayer (ProXP)
NetServer (ProXP)
Open DivX 5.02 (ProXP,PlayerXP)
Scalar ActiveX Filter (ProXP,PlayerXP,Not Installed as Typical)
Scalar DirectShow Filter (ProXP,PlayerXP,Not Installed as Typical)
TrueMotion Decompressor ActiveX Filter (ProXP)
Universal AC3-MPEG Audio Layer 2-3 Decoder Filter (ProXP,PlayerXP)
WAV-Dest ActiveX Filter (ProXP,PlayerXP)
XviD (ProXP,PlayerXP)
CoDecs
3ivx CoDec (ProXP)
420 CoDec (ProXP,PlayerXP)
Adaptec DVSoft CoDec (ProXP)
ASUS Video CoDec V1 (ProXP)
ASUS Video CoDec V2 (ProXP)
ATI VCR 1 Format [VCR1] CoDec (ProXP)
ATI VCR 2 Format [VCR2] CoDec (ProXP)
ATI YV12 Planar Format CoDec (ProXP)
Autodesk FLI/FLC CoDecS (ProXP)
Avid AVI CoDec (ProXP)
AVImszh CoDec (ProXP)
AVIzlib CoDec (ProXP)
Aware MotionWavelets Video Codec (ProXP)
Brooktree Prosumer Video CoDec (BT20 and Y41P) (ProXP)
Canopus DV Audio CoDec (ProXP)
Canopus Software DV CoDec (CDVC) (ProXP)
Canopus Software DV CoDec (DVSD) (ProXP)
Cinepack CoDec (ProXP)
Darim Vision DVMPEG Audio CoDec (ProXP)
Darim Vision DVMPEG Video CoDec (ProXP)
DPS AVI CoDec (ProXP)
DPS Video Capture CoDec (ProXP)
DSP Group TrueSpeech Audio CoDec (ProXP)
Etymonix MPEG-2 I-frame CoDec (ProXP)
Forward MJPEG CoDec (ProXP)
Forward Uncompressed CoDec (ProXP)
Gabest GLZW Video CoDec (ProXP)
Gabest GPEG Video CoDec (ProXP)
Huffyuv LossLess [HFYU] CoDec (ProXP)
Indeo 3.2 CoDec (ProXP,PlayerXP)
Intel I.263 CoDec (ProXP,PlayerXP)
Intel Indeo 3.1 and 3.2 CoDec (ProXP,PlayerXP)
Intel Indeo RAW R2.1 CoDec (ProXP,PlayerXP)
Intel Indeo Video 4.10 CoDec (ProXP,PlayerXP)
Intel Indeo Video 5.11 CoDec (ProXP,PlayerXP)
Intel Indeo Video iYUV R2.0 CoDec (ProXP,PlayerXP)
Intel Indeo Video RAW R1.2 CoDec (ProXP,PlayerXP)
Intel Music Coder CoDec (ProXP,PlayerXP)
Lame MP3 Encoder ACM CoDec (ProXP,PlayerXP)
LEAD MCMP/MJPEG CoDec (ProXP)
Lernout&Hauspie Codecs Audio CoDec (ProXP)
MainConcept DV Software CoDec (ProXP,PlayerXP)
MainConcept Motion JPEG Video CoDec (ProXP,PlayerXP)
Matrox Software DV and DVCPRO and DVCPRO50 CoDec (ProXP)
Matrox Software DV/DVCPRO/DVCPRO50 CoDec (ProXP)
Matrox Software MJPEG CoDec (ProXP)
Matrox Software MPEG-2 I-Frame CoDec (ProXP)
Microsoft Adaptive PCM Audio CoDec (ProXP,PlayerXP)
Microsoft ADPCM Audio CoDec (ProXP,PlayerXP)
Microsoft G.711 Audio CoDec (ProXP,PlayerXP)
Microsoft G.723.1 Audio CoDec (ProXP,PlayerXP)
Microsoft GSM 6.10 Audio CoDec (ProXP,PlayerXP)
Microsoft H.261 CoDec (ProXP,PlayerXP)
Microsoft H.263 and 420 CoDec (ProXP,PlayerXP)
Microsoft MPEG-4 Video CoDec (ProXP,PlayerXP)
Microsoft RLE CoDec (ProXP,PlayerXP)
Microsoft UYVY and YUY2 and YVYU CoDec (ProXP,PlayerXP)
Microsoft Video1 CoDec (ProXP,PlayerXP)
Miro-XL 32 Video CoDec (ProXP)
Morgan Multimedia (TVMJ/FLJP)
LSI M-JPEG CoDec Morgan Multimedia MJPEG 2000 CoDec (ProXP)
Morgan Multimedia MJPEG CoDec (ProXP)
MPEG Layer-3 Professional Audio CoDec (ProXP,PlayerXP)
Newtek HDTV CoDec (ProXP)
Ogg Vorbis Audio CoDec (ProXP,PlayerXP)
On2 VP3 CoDec (ProXP)
Panasonic DV CoDec (ProXP)
Paradigm Matrix M-JPEG CoDec (ProXP)
Pegasus PICVideo Lossless JPEG CoDec (ProXP)
Pegasus PICVideo MJPEG CoDec (ProXP)
Pegasus Wavelet 2000 CoDec (ProXP)
Pinnacle DV25 CoDec (ProXP)
Pinnacle ReelTime CoDec (ProXP)
Prosumer Video CoDec (Y41P) (ProXP)
QDesign MPEG Audio CoDec (ProXP)
REALmagic MPEG-4 Video CoDec (ProXP)
Rududu CoDec (ProXP)
Sipro Lab Telecom Audio CoDec (ProXP)
Sony ATRAC3 Audio CoDec (ProXP)
Sony Software DV CoDec (ProXP)
TechSmith Screen Capture CoDec (ProXP)
Tekram YUV CoDec (ProXP)
Toshiba YUV CoDec (ProXP)
VFAPI Reader CoDec (ProXP,PlayerXP)
Video Server Wrapper Audio/Video CoDec (ProXP,PlayerXP)
Videum WNV1 CoDec (ProXP)
VorbisACM (ProXP,PlayerXP)
WMA Audio CoDec (ProXP,PlayerXP)
YUV2 CoDec (ProXP,PlayerXP)
Registry FileS
WinDVD Output Settings (ProXP,PlayerXP)
ActiveMovie Output Settings (ProXP,PlayerXP)
ACE Mega CoDecS Pack - Quality Settings (ProXP,PlayerXP)
Individual Configuration FileS - Quality Class (ProXP,PlayerXP)
ShurtCut FileS
DirectVobSub Configure (ProXP,PlayerXP)
DivX Configure (ProXP,PlayerXP)
DivXAF Configure (ProXP,PlayerXP)
DivXG400 Configure (ProXP,PlayerXP)
VobSub Cutter (ProXP,PlayerXP)
VobSub Joiner (ProXP,PlayerXP)
ProgramS
abcAVI Tag Editor (ProXP,PlayerXP)
ACM Prop (ProXP)
AVI Chop (ProXP)
AVI CoDecS (ProXP)
AVI FourCC Code Changer (ProXP)
AVI Frame Rate Changer (ProXP)
AVI MuX (ProXP)
AVIChop (ProXP)
AVIcodec (ProXP)
AVIDeFreezer (ProXP)
AyeSeeThreeDecode (ProXP)
DirectSound 3D Renderer Configurator (ProXP,PlayerXP)
DirectSound 3D Filter Configurator (ProXP,PlayerXP)
DivFix (ProXP)
DivX Decoder Properties (ProXP,PlayerXP)
DivX Fix (ProXP,PlayerXP)
DivX Playback Configurator (ProXP,PlayerXP)
DivX Validator (ProXP)
DX Man (ProXP)
File Merger (ProXP)
Graph Edit (ProXP,PlayerXP)
Ligos MPEG Configuration Utility (ProXP,PlayerXP)
Mini AviC FourCC Changer (ProXP)
LSI M-JPEG CoDec Tray (ProXP)
Morgan Multimedia MJPEG 2000 CoDec Tray (ProXP)
Morgan Multimedia MJPEG CoDec Tray (ProXP,PlayerXP)
MPEG Layer 3 Configure (ProXP,PlayerXP)
MPEG-4 Codec Configure (ProXP,PlayerXP)
Network Streaming (ProXP)
OggCut (ProXP)
oggdropXPd (ProXP)
OggMuX (ProXP)
RemovePath (ProXP)
StatsReader (ProXP)
SubMuX (ProXP)
SubReSync (ProXP)
UDPStreaming (ProXP)
Validator (ProXP)
Vorbis Tools (ProXP)
XMuxeR (ProXP)
ZoomPlayer (ProXP,PlayerXP)
So basicly what you have done is installed all these components without the need or the understanding of what you were doing,
You may have to reinstall windows to correct all the faults
Brian :rock:
Homer   , The Odyssey, line 1
« Reply #2 on: July 14, 2003, 00:42 »
Thank you Lobo for your really very beautiful and nice spirit of giving and sharing your knoledge with others. Your being any time ready to help.
     Merci Beaucoup mon cher ami.   :thanks:
Offline lobo
« Reply #3 on: July 14, 2003, 10:03 »
@joudi
Always a pleasure my friend, if my reply was a bit terse then I apologise to you but you must admit that it was informative and helpful.   The time to ask questions about software you are going to install on your computer is before you install it not after, it is easier to help people before the damage is done, If I had replied just reinstall Windows you may not have understood the problem that can be caused by the simple installing of software and be tempted to install it again
 Brian  :brick: :lol:
