November 28, 2024, 00:51
Technical Help & Discussion
Software, Hardware & Website Recommendations
Instant Messaging for Travellers
Topic: Instant Messaging for Travellers (Read 1357 times)
chorleydave
July 14, 2003, 00:13 »
Although I am a Trillian user, I used to use a messenger called "Easy Message". Like Trillian, this will connect to MSN, ICQ, AOL & Yahoo. I stopped using it because at the time the program was new and a bit flakey.
I've just been to the website, because I have been looking for another messenger for the sole use of my son. It hadn't occurred to me, but as the program is a mere 200KB in size, the author suggests that it is ideal for travellers as it can be run from a floppy disk.
Easy Message is freeware and can be dowloaded at
http://www.easymessage.net
Re:Instant Messaging for Travellers
July 14, 2003, 07:46 »
Yes, on my travels to find the ideal messenger service, I gave Easy Message a try out. As you say, Dave, it was a bit flaky, but looks almost identical to MSN Messenger, and at such a small size, could be useful to some.
