Right a few questions for the learned,
I have today installed an extra HDD, primarily so that I can back up my OS /programs/data in case of HDD failure.
Now Disk No 1 a 40GB HDD is split into C: drive 30GB [9 GB used] status: Primary boot. And D: drive 10GB [1GB used] status: Primary extended logical.
Disk No 2, the new 30GB HDD is split into [unallocated Primary size 7.8MB] with extended Primary split into logical partitions G: and H: and for now unused, but obviously I can have more partitions.
Presently Disk No 1 has W2K OS and programs are on C: drive, and my data and files are on D: drive. Now whilst I will be saving a compressed image of C: and D: drives onto the new HDD [I have PQ Drive Image] lets just consider if the 40GB HDD does go belly up.
I was thinking:
![Rolleyes ::)](http://www.pc-pals.com/smf/Smileys/Smileys/rolleyes.gif)
Would it be possible to set Disk No 2 up, so that I could restore/copy the saved image of Disk No 1 onto two drives on Disk No2 ?
Drives set up right now as Disk No1 Master, Disk No2 Slave, is it possible to set Disk No 2 up as bootable with W2K installed on it also, I mean as I?m I right in thinking as long as Disk No1 is bootable it would boot the OS on that disk. What I?m asking is, if Disk No 1 was not bootable either corrupted OS or HDD failure would it boot off Disk No 2 if the boot sequence was C:/A:/ G: or I?m I talking complete bollards.
If bollards is the answer, if Disk No1 fails will I have to whip open the case and set Disk No2 to Master and swap the cable connectors over, and make a primary active partition using Partition Magic.
Well let the lesson begin
PS: choices with HDD's Master / Slave / and Cable enable, first to are self explanatory but why the option 'Cable Enable'
