November 28, 2024, 03:00
Technical Help & Discussion
Software, Hardware & Website Recommendations
Compression Tool Showdown
Topic: Compression Tool Showdown (Read 1444 times)
Robotochan
Established Member
July 16, 2003, 15:34 »
Hey all, attached is the results from a large test I performed on 4 of the largest used compression tools, WinAce, WinRAR, WinZip 8.1 SR-1 and WinZip 9.0 Beta. Enjoy
PS. You might want to save the file using the red link underneath this text
b]Oxymoron: [/b]
Example:
Microsoft Works
Sandra
Ultimate Member
Re:Compression Tool Showdown
July 16, 2003, 15:42 »
Nicely done Robo
Looks like I will have to use Winace and Winrar more often now as your results show a 25% reduction in file size over Winzip.
I usually use Winzip as most people can unzip those,so they will have to get Winrar and Winace installed now as well
Robotochan
Established Member
July 16, 2003, 19:12 »
WinRAR is the better of the 2 as it can also open ACE files I think, plus more people use it than WinAce
b]Oxymoron: [/b]
Example:
Microsoft Works
