Author Topic: XP Safe Mode  (Read 4793 times)
XP Safe Mode
« on: July 18, 2003, 18:53 »
OK, I'm probably being thick again, but with XP, I can only boot into safe mode if I first go into MSCONFIG,  and tick Safe Mode under Boot Options, then it will only boot into safe mode, until I untick the box again.
Why won't the F8 trick work?  Is it me, or a thing with XP?
Re:XP Safe Mode
« Reply #1 on: July 18, 2003, 19:03 »
Search my Simon,
being on W2K, but seeing as we are mentioning the F word. Which key do you hold down at boot up to read the boot up screen  ???
Re:XP Safe Mode
« Reply #2 on: July 18, 2003, 19:04 »
Maybe you aren't pressing it at the right time?  :-\ It should be pressed before Windows starts to boot, just after the BIOS summary screen disappears.
Re:XP Safe Mode
« Reply #3 on: July 18, 2003, 19:33 »
Tony - sorry, not sure what you mean.
Sean - tried that!  :-\
Re:XP Safe Mode
« Reply #4 on: July 18, 2003, 20:19 »
Are you leaving it long enough Simon?
Sometimes on mine it seems to hang at something like xxxxxx.mupp (I think it is) then eventually it gives me the options of safe mode and last good configuration etc  ???
Re:XP Safe Mode
« Reply #5 on: July 18, 2003, 20:30 »
Oh, now I know which screen Tony was referring to.   ;D
I'll try it next time I boot up, but that's another thing - this damned Fujitsu modem very often won't initialise after a reboot, won't reset either, then causes a hang on shutdown, so I tend to reboot as little as possible.
Re:XP Safe Mode
« Reply #6 on: July 18, 2003, 20:35 »
It won't help you I know Simon, but here is Microsoft's Knowledgebase Article about Safe Mode
Offline lobo
    • http://www.burnleywood.com
Re:XP Safe Mode
« Reply #7 on: July 18, 2003, 20:50 »
Right click on My Computer, Properties, select the Advanced Tab and click on the Startup and Recovery Settings button, alter the ?Time to display recovery options when needed? to 30 seconds and the same for ?Time to display list of operating Systems?
When you reboot keep the F8 key depressed until the recovery screen appears, this screen will then show for 30 seconds select Safe Mode and press enter, select XP and press enter, that should work
Brian ::)
Homer   , The Odyssey, line 1
Re:XP Safe Mode
« Reply #8 on: July 18, 2003, 21:01 »
Hi Brian, the Start Up and Recovery details are already as you said (see below).  I've just restarted, and held the F8 key down right through, and it still didn't boot into safe mode.  The recovery screen does not appear.
Re:XP Safe Mode
« Reply #9 on: July 18, 2003, 21:05 »
Simon, try pressing F8 as rapidly as you can from the time the BIOS screen is about to disappear until the menu appears :-\
Offline lobo
Re:XP Safe Mode
« Reply #10 on: July 18, 2003, 21:05 »
@Simon
What kind of keyboard m8, if its USB could be your problem
Brian ;D
Re:XP Safe Mode
« Reply #11 on: July 18, 2003, 21:08 »
DOH!
Of course ::) - he has a USB keyboard! Well done Brian. It's always the bloody obvious isn't it? :lol:
Edit: Does the USB Keyboard Legacy Mode setting in the BIOS have anything to do with this problem?
Re:XP Safe Mode
« Reply #12 on: July 18, 2003, 21:11 »
Could that be Arthurs problem if he has a nonstandard keybouard?
I remember having my fancy Office Navigator keyboard connected at one time and the F keys dont function until windows has loaded the drivers so I had to revert back to a basic one  :(
Re:XP Safe Mode
« Reply #13 on: July 18, 2003, 21:11 »
Simon, a little bit of advice.  Change to WinME. I don't have all those problems you seem to have. :P ;)
Offline lobo
Re:XP Safe Mode
« Reply #14 on: July 18, 2003, 21:22 »
"Does the USB Keyboard Legacy Mode setting in the BIOS have anything to do with this problem? "
Not certain if the USB drivers are installed before the recovery screen loads, Simon could boot into DOS and try all the keys on the board
Brian ;D
