Author Topic: Ddhelp can you help?  (Read 2282 times)
Offline Shaz
« on: July 19, 2003, 22:18 »
Hiya guys,over the last few days about 4 times,when im shutting my pc down I get a box up it says
"An error has occured in your program.To keep working anyway,click ignore and save your work to a new file.To quit this program,click close.You will lose information you entered since your last save"
when i click close ,another window comes up saying
"this program has performed an illegal operation and will be shut down"
 I havent the fainest idea what this is related to or why it keeps doing it.im just trying to turn my pc off.Can you help please.
een away but back with a vengence!!!!
Re:Ddhelp can you help?
« Reply #1 on: July 19, 2003, 22:50 »
What programs do you have running when you shut down, Shaz?  It sounds like something isn't being closed down properly when you shut down your PC.
« Reply #2 on: July 19, 2003, 22:54 »
You should see a "Details" button in the warning box.  Click on "Details" and it should tell you which program is causing the problem.
Offline Shaz
« Reply #3 on: July 20, 2003, 00:00 »
The program is called 'Ddhelp'thats what it says in the window, the only programs i have running at the time are MSN,outlook express,my saved documents and pc-pals.
« Reply #4 on: July 20, 2003, 00:20 »
Its something that must be running in the background on startup Shazso if you look and see whats loading at start up you should be able to untick it from there.
If its just an inconvenience on shutting down I would leave it until your Dave has time to have a look as you want to run MSCONGIG and go to startup to see what it is  :-*
« Reply #5 on: July 20, 2003, 09:23 »
DDHELP is something to do with Direct Draw, which is, again, something to do with DirectX and graphics.
Sorry to be a bit vague, but there's loads of stuff on Google if you search for 'ddhelp', but I couldn't find anything specific to your problem, Shaz.
I'm sure Adept or Brian will have the answer.  Just a thought, have you recently updated DirectX or your graphics card?
« Reply #6 on: July 20, 2003, 11:32 »
I have no idea what could be causing this Shaz, sorry.
A couple of things you could try:-
1. Make sure that no programs are running when you shut the PC down. This includes any "background" programs that have icons in the system tray (next to the clock)
2. Reinstall DirectX which you will be able down load from Microsoft
Let us know if you need any further help with these :)
Offline Shaz
« Reply #7 on: July 20, 2003, 11:57 »
Thanks for your input guys,will try reinstalling directx and let you know what happens. ;D
Offline lobo
    • http://www.burnleywood.com
« Reply #8 on: July 20, 2003, 16:24 »
@Shaz
Adept is correct when he recomends reinstalling DirectX
ddhelp = Microsoft DirectX Helper
This behavior can occur if your DirectX video driver is damaged or incorrectly installed.
To resolve this issue, follow these steps:
Download the current version of DirectX.
Right-click the desktop, and then click Properties.
Click the Settings tab, and then click Change Display Type or Advanced Properties. Note the name of your display driver.
Click Change in the Adapter Type section, and then click Show All Devices.
In the Manufacturers box, click Standard Display Types.
In the Models box, click Standard Display Adapter (VGA), click OK, and then click Close.
Click OK twice.
Click Yes if you are prompted to restart your computer.
Reinstall DirectX.
Brian ;D
Homer   , The Odyssey, line 1
Offline Shaz
« Reply #9 on: July 20, 2003, 22:17 »
Thankyou again everyone. I sucsessfully installed new version of directx and am hoping it stops this annoying problem will let you know in a couple of days! :thanks: ;D
Offline Shaz
« Reply #10 on: July 22, 2003, 22:37 »
Hi,Just want to say thanx to you all especially Lobo,since i took your advice the problems not returned! :clever: :thanks:XXXXXX
« Reply #11 on: July 22, 2003, 23:43 »
Good news, Shaz - glad you got it sorted.   :D
Offline lobo
« Reply #12 on: July 23, 2003, 00:25 »
Hi Shaz
Nice to see that you got it sorted my friend
Brian :go:
