Author Topic: Looking for a File  (Read 1204 times)
Offline bmjjmass
  • New Registration
Looking for a File
« on: July 20, 2003, 14:22 »
I have a old computer and it crashes every now & then. I use the reboot disc to restore it back to the original factory settings. My problem is I can't install Microsoft Works 3.0. When I try the software tells me I'm missing the file "share.exe". I had this program before in my system so how can it be possible to be missing this file now? Is there somewhere I can go to download this file or what can I do to install my software? Thanks for any help!
Re:Looking for a File
« Reply #1 on: July 20, 2003, 14:48 »
Hi and welcome to the forum.
According to this article on MS Knowledge base it sounds like you may have it in your Autoec.bat but not in the Congif.sys file :
http://support.microsoft.com/default.aspx?scid=kb;en-us;108601
Hope that this helps  :-*
