Author Topic: Software to Edit Scanned Images  (Read 1639 times)
« on: July 23, 2003, 16:05 »
Can anyone recommend software that may be used to open a scanned image (saved to floppy disk) and then used to edit the text while leaving the heading images intact?
Thanks
Offline DJ
Re:Software to Edit Scanned Images
« Reply #1 on: July 23, 2003, 16:39 »
Do you just need a standard image software (ie PhotoShop) or OCR software, where the computer recognises the words scanned and then can be edited like a normal document in Microsoft Word for example?
Is there any software that came bundled with your scanner?
DJ1UK
« Reply #2 on: July 23, 2003, 16:51 »
Hi DJ.
I'm looking for OCR software, as I want to edit the text.  I will be using the scanner in the local library, as  I haven't got one, hence I will have to save to floppy, or alternatively e-mail the document to myself so that I can edit it back here.
« Reply #3 on: July 23, 2003, 17:51 »
Not sure what OCR software is, but I use Adobe Photoshop Elements, which can do that job, Dave.  You can 'erase' the existing text, by painting over it (like Tipex), then replace it with your own.  Not sure if that's what you had in mind though.
P.S. You have a PM.
« Reply #4 on: July 23, 2003, 17:53 »
Its Optical Character Recognition software Simon  :-*
Offline lobo
    • http://www.burnleywood.com
« Reply #5 on: July 23, 2003, 22:32 »
Thanks
Omnipage Pro 12 is the best my friend followed by Textbridge,
Brian ;D
Homer   , The Odyssey, line 1
