hi
have a tecra 8200 laptop that boots up very slow.
ideally i would like to format the c drive and reload everything but the floppy drive is designated 'F' drive and is external with a USB connection(there is no 'A' drive although if you double click on my computer icons for floppy drives show on 'A' & 'F').
the Bios is set to check FDD, HDD, LAN then CD-ROM, but if i put my boot disk in the floppy drive 'F' it doesn't see it at start up.
is there anything i can do to make the computer boot up from my boot disk.
anything that will help in anyway i would be most grateful
thanks
