Author Topic: floppy drive  (Read 901 times)
Offline clam
floppy drive
« on: July 24, 2003, 11:44 »
hi
have a problem - i only have 1 fdd it is an external fdd (usb connection) for my laptop designated 'F' drive.
but in my computer 2 fdd's show one designated 'A' and 1 designated 'F' anytime i try to install anything from floppy it always tries to install from 'A' which isn't there so the full computer hangs.
thanks
Re:floppy drive
« Reply #1 on: July 24, 2003, 14:03 »
Can you access the BIOS and tell it that A drive isnt being used ,similar to most PCs where it says Drive B not installed.
Not being rich I have never had a laptop or any experience with them  ???
Re:floppy drive
« Reply #2 on: July 24, 2003, 16:21 »
Do you run Windows Millennium Edition clam?
If so, this Microsoft Knowledgebase article may point you in the right direction :)
