Author Topic: Best personality test - ever!  (Read 4046 times)
« on: July 24, 2003, 17:01 »
It's long but VERY accurate when it comes to result if you are honest with yourself...
answer this:
http://www.humanmetrics.com/cgi-win/JTypes2.asp
and then check here to see what personality type you are and read about it:
http://www.personalitypage.com/portraits.html
Mine?  Here you go:
Your Type is
ENFJ
Extroverted Intuitive Feeling Judging
Strength of the preferences %
11 44 11 56
Qualitative analysis of your type formula
You are:
slightly expressed extrovert
moderately expressed intuitive personality
slightly expressed feeling personality
moderately expressed judging personality
Re:Best personality test - ever!
« Reply #1 on: July 24, 2003, 19:26 »
Your Type is
ISFJ
Introverted Sensing Feeling Judging
78 33 11 44
ISFJ type description by D.Keirsey
ISFJ type description by J. Butt and M.M. Heiss
 You are:
very expressed introvert
moderately expressed sensing personality
ISFJs are often unappreciated, at work, home, and play. Ironically, because they prove over and over that they can be relied on for their loyalty and unstinting, high-quality work, those around them often take them for granted--even take advantage of them. Admittedly, the problem is sometimes aggravated by the ISFJs themselves; for instance, they are notoriously bad at delegating ("If you want it done right, do it yourself").
Well that's me to a Tee :o
« Reply #2 on: July 24, 2003, 19:40 »
Told you it was good!  I can't disagree with what it says about you either.
A quote from mine is:
ENFJs are people-focused individuals. They live in the world of people possibilities. More so than any other type, they have excellent people skills. They understand and care about people, and have a special talent for bringing out the best in others. ENFJ's main interest in life is giving love, support, and a good time to other people. They are focused on understanding, supporting, and encouraging others. They make things happen for people, and get their best personal satisfaction from this.
Offline lobo
    • http://www.burnleywood.com
« Reply #3 on: July 24, 2003, 20:56 »
Your Type is
INTJ
moderately expressed introvert
slightly expressed intuitive personality
slightly expressed thinking personality
INTJs are perfectionists, with a seemingly endless capacity for improving upon anything that takes their interest. What prevents them from becoming chronically bogged down in this pursuit of perfection is the pragmatism so characteristic of the type: INTJs apply (often ruthlessly) the criterion "Does it work?" to everything from their own research efforts to the prevailing social norms. This in turn produces an unusual independence of mind, freeing the INTJ from the constraints of authority, convention, or sentiment for its own sake.
INTJs are idea people. Anything is possible; everything is negotiable. Whatever the outer circumstances, INTJs are ever perceiving inner pattern-forms and using real-world materials to operationalize them. Others may see what is and wonder why; INTJs see what might be and say "Why not?!" Paradoxes, antinomies, and other contradictory phenomena aptly express these intuitors' amusement at those whom they feel may be taking a particular view of reality too seriously. INTJs enjoy developing unique solutions to complex problems.
Thats me to a "T"
Brian ;D ;D
Homer   , The Odyssey, line 1
Offline Robotochan
« Reply #4 on: July 30, 2003, 13:39 »
I'm the same as Lobo  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline Serenity
« Reply #5 on: July 30, 2003, 14:23 »
I am the same as CLIVE  :o  ENFJ!  Im starting to get slightly worried Clive, we seem to have identical results on most of these tests! I hope we are not in some way genetically linked  :o  I couldnt face the humiliation  :P  ;D
Offline lobo
« Reply #6 on: July 30, 2003, 15:06 »
Us INTJs must stay together  ;D
Brian :go:
« Reply #7 on: July 30, 2003, 15:45 »
Since I never met my father we could have the same one Serenity!  Did I tell you my brother hung himself?  I probably did.  He was always more highly strung than me.  We extroverts must stick together Serenity.
 :banana:  :banana: :banana:  :banana:  :banana:
« Reply #8 on: July 30, 2003, 19:00 »
Your Type is ENTP
Extroverted Intuitive Thinking Perceiving
Strength of the preferences % 22 56 11 11
You are:  slightly expressed extrovert
slightly expressed perceiving personality
Click HERE for a spookily accurate explanation of what goes on inside my head!   :o
Offline Shaz
« Reply #9 on: July 30, 2003, 19:38 »
Im the same as Clive and Serenity :D
Because ENFJ's people skills are so extraordinary, they have the ability to make people do exactly what they want them to do. They get under people's skins and get the reactions that they are seeking. ENFJ's motives are usually unselfish, but ENFJs who have developed less than ideally have been known to use their power over people to manipulate them.
Oh my God I think the people who invented this test have been spying on me!!!
This quote is me to a T. ;)
een away but back with a vengence!!!!
« Reply #10 on: July 30, 2003, 21:38 »
"ENTP's natural partner is the INFJ, or the INTJ. The ENTP's dominant function of Extraverted Intuition is best matched with a personality that is dominated by Introverted Intuition."
Well whaddya know!   8)
Offline Shaz
« Reply #11 on: July 30, 2003, 22:41 »
My fella is INTP.He says some of its like him.I say its exactly him!! ;D
« Reply #12 on: July 30, 2003, 22:46 »
I've never had a fella, myself.  So I'll trust your judgement on this one, Shaz.   ;)
Offline Michelle
    • Techieminx
« Reply #13 on: August 15, 2003, 12:58 »
Your Type is
INFP
Introverted Intuitive Feeling Perceiving
22 44 33 33
 You are:
slightly expressed introvert
moderately expressed feeling personality
moderately expressed perceiving personality
Healer Idealists are abstract in thought and speech, cooperative in striving for their ends, and informative and introverted in their interpersonal relations. Healer present a seemingly tranquil, and noticiably pleasant face to the world, and though to all appearances they might seem reserved, and even shy, on the inside they are anything but reserved, having a capacity for caring not always found in other types. They care deeply-indeed, passionately-about a few special persons or a favorite cause, and their fervent aim is to bring peace and integrity to their loved ones and the world.
awwwwwww  :)
« Reply #14 on: August 15, 2003, 13:04 »
It missed off pi$$head!!   ;) ;D ;D ;D
