Author Topic: Notepad and Wordpad  (Read 2436 times)
Notepad and Wordpad
« on: December 01, 2002, 20:50 »
Can anyone tell me what the difference is between Notepad and Wordpad in Accessories?  They both seem very similar to me.
Re:Notepad and Wordpad
« Reply #1 on: December 01, 2002, 20:53 »
Notepad is a simple text editor Clive, whereas WordPad is more of a simple wordprocessor which can format text with fonts, justification, tab stops etc.
« Reply #2 on: December 01, 2002, 20:57 »
Thanks Adept.  I'm getting split lines again despite using Notepad.  On my old computer, Notepad seemed slightly different.  Perhaps the default font has changed.
« Reply #3 on: December 01, 2002, 21:02 »
Have you tried turning off 'Word wrap' Clive?
« Reply #4 on: December 01, 2002, 22:15 »
Word Wrap was already off.  I'll have to try playing about with it until I get it right again.  I should have taken note of the settings I used on my old machine, but it's gone now.
