Author Topic: scandisk problem  (Read 6411 times)
Offline alphafalcon
scandisk problem
« on: July 27, 2003, 16:06 »
Hey guys, Could you help me enable to scandisk to my drive C..Whenever i tried to scandisk my drive C. theres a message that says............"Scandisk cannot continue because a program such as a disk utility has locked this drive. CLose the program or wait for it to finish. Then restart Scandisk."..........i really needed some help here :-[
my oem is windows me..
Re:scandisk problem
« Reply #1 on: July 27, 2003, 16:12 »
Hi alphafalcon :welcome:
I have seen this problem a few times on Windows 98. The solution I've used is to run Scandisk in Safe Mode.
To get to Safe Mode, restart your PC and just before the PC says Starting Windows Millennium Edition, press F8 a few times. This should make a menu appear from which you can select Safe Mode.
Once Safe Mode Windows loads, you should be able to run Scandisk without any problems.
Re:scandisk problem
« Reply #2 on: July 27, 2003, 16:12 »
Try restarting in safe mode and running it in there Alphafalcon  :-*
Re:scandisk problem
« Reply #3 on: July 27, 2003, 16:13 »
Beat me by seconds Adept :doggie:
Re:scandisk problem
« Reply #4 on: July 27, 2003, 16:16 »
And I was far more informative too Sandra :P :banana:
Re:scandisk problem
« Reply #5 on: July 27, 2003, 16:24 »
Thats because youre a man and talk too much,whereas I was clear and precise and to the point  :P
Re:scandisk problem
« Reply #6 on: July 27, 2003, 16:27 »
Do the words pot, kettle and black mean anything to you Sandra  :brick: ;D ;D
Offline alphafalcon
Re:scandisk problem
« Reply #7 on: July 27, 2003, 16:28 »
ive tried the safe mode... and enabling the scandisk to drive C but its not working :(..the same message appears..
Re:scandisk problem
« Reply #8 on: July 27, 2003, 16:30 »
Do you have Norton System Works running?
Apparently it has a background disk defragmenter program which can cause similar behaviour.
Offline alphafalcon
Re:scandisk problem
« Reply #9 on: July 27, 2003, 16:34 »
yes adept.. i have norton system works..how can i solve this problem?
Re:scandisk problem
« Reply #10 on: July 27, 2003, 16:35 »
Thats awkward  :(
Have you got a disk management utility which you used to make your PC see a larger drive than the BIOS would originally "see" ?
I fitted a 40 gig drive in my 450 pc once and it wouldnt recognise it until I flashed the bios.
Prior to flashing the bios I overcame the problem with Seagates disk management utility which then caused problems with some programs at a later date that were only resolved by flashing the bios and then wiping the drive to get rid of the seagate utility.
Offline Mustapha Phagg
Re:scandisk problem
« Reply #11 on: July 27, 2003, 16:43 »
Why not run scandisk in dos mode, then there's nothing to conflict with it.
Re:scandisk problem
« Reply #12 on: July 27, 2003, 16:54 »
I hope it's not Norton Systemworks 2000 alphafalcon :o
See this Microsoft Knowledgebase article.
Mustapha: Alpha can't run in DOS mode, Windows ME doesn't have one unfortunately :(
Re:scandisk problem
« Reply #13 on: July 27, 2003, 16:58 »
Can you not boot to dos with a 98 boot disk Adept then run scandisk from C prompt?
Re:scandisk problem
« Reply #14 on: July 27, 2003, 17:00 »
Dammit Sandra you beat me to it. :(
