Author Topic: The Privacy Test  (Read 1571 times)
The Privacy Test
« on: July 31, 2003, 17:24 »
Another "Just for fun" test to find out how open you are.
http://www.queendom.com/tests/minitests/fx/privacy.html
My results:
While you're not obsessed with closing guarding your privacy, there are certain areas of your life what you just don't want to share with others. Perhaps you feel uncomfortable divulging certain pieces of information, or it simply depends on the people you are dealing with. Whatever the case, it seems you know how to use your judgment and decide whether or not to disclose personal info or put yourself on open display. This protects you from the potential humiliation that could happen if the juicy tidbits made their way into the wrong hands. A balance between discretion and openness is the way to go...and you seem to be on the right track.
Offline Shaz
Re:The Privacy Test
« Reply #1 on: July 31, 2003, 18:04 »
Well what do you know Clive we got the same result again!!! ;D
I like these tests keep em coming mate!
een away but back with a vengence!!!!
Re:The Privacy Test
« Reply #2 on: July 31, 2003, 18:06 »
Your Score = 40
Quite surprising.  As I trust very few humans, I expected to be more private than I am.
Re:The Privacy Test
« Reply #3 on: July 31, 2003, 18:21 »
Hmmmm... Not sure about this one Clive :)
Your score = 45
What does your score mean?
Re:The Privacy Test
« Reply #4 on: July 31, 2003, 18:32 »
 :P
Re:The Privacy Test
« Reply #5 on: July 31, 2003, 19:24 »
Well that's interesting.  We all had the same result.  I take it that we are all prepared to go naked in the sauna then?   :heehee:
Offline Camstop
Re:The Privacy Test
« Reply #6 on: July 31, 2003, 19:49 »
Your score = 55
Re:The Privacy Test
« Reply #7 on: July 31, 2003, 19:58 »
85  :o
You're a bit of an open book - you share highly personal information with other people, and don't get uptight about revealing even the unattractive side of yourself. This likely comes from a high level of confidence and the belief that others have to accept you as is, warts and all. This candidness is generally an attractive trait that allows you to build close relationships and demonstrates to others that you trust them. Make sure, however, that you use your discretion. Revealing personal information or openly engaging in "controversial" activities could get you in some rather compromising positions.
Open Book .. yeah right  :-X
Re:The Privacy Test
« Reply #8 on: July 31, 2003, 20:33 »
My score = 50
That's actually quite accurate about me, but it's a bit suspect that we all seem to get the same.  Except one, of course!   ::) ;D ;D
Re:The Privacy Test
« Reply #9 on: August 01, 2003, 19:02 »
I lied  ;D.. nobody gets to know me.. not even a computer  :P
