Author Topic: Msg 6  (Read 2704 times)
Msg 6
« on: July 31, 2003, 19:48 »
Anybody else running the new MSN Messenger 6.. looks a lot better than the older versions  ;D only time will tell  8)
Hookstar
Offline GSS
    • artzone4u.com
Re:Msg 6
« Reply #1 on: July 31, 2003, 22:31 »
i got it its ok so far but more high tec more problens you get  8)
www.artzone4u.com
banner coming soon
Offline Robotochan
Re:Msg 6
« Reply #2 on: August 01, 2003, 17:53 »
I've had it for quite a while and I have MSG Plus for it too  ;D Ahh checkers is such a good game when you win
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline greenking
Re:Msg 6
« Reply #3 on: August 01, 2003, 18:38 »
I've had it for a couple of weeks Hook and I like it  8)
Re:Msg 6
« Reply #4 on: August 01, 2003, 18:42 »
GK.........it only popped up yesterday on my MSG.. :o
Offline Shaz
Re:Msg 6
« Reply #5 on: August 01, 2003, 19:13 »
Im same as you hooky asked me if I wanted to download it yesterday which I did. I love it, its loads more fun than the previous ones ;D
een away but back with a vengence!!!!
Re:Msg 6
« Reply #6 on: August 01, 2003, 19:17 »
Loads more silly faces  :P
Re:Msg 6
« Reply #7 on: August 01, 2003, 19:36 »
Yes, I remember them asking me for permission to use my photo.
Re:Msg 6
« Reply #8 on: August 01, 2003, 19:49 »
Re:Msg 6
« Reply #9 on: August 01, 2003, 20:52 »
Can you re-name your contacts now, or do you still have to put up with the full e-mail addresses cluttering things up?
Offline Shaz
Re:Msg 6
« Reply #10 on: August 01, 2003, 21:35 »
Hiya Si, Ive just had alook and you can rename your contact ;DI really like it.Id recommend it to anyone! :go:
Re:Msg 6
« Reply #11 on: August 01, 2003, 23:09 »
I really like it.
We knew that Shaz you told us how good it was with Tony already remember  ;)
Offline Shaz
Re:Msg 6
« Reply #12 on: August 01, 2003, 23:15 »
:heehee: :baad: :boobs:
Re:Msg 6
« Reply #13 on: August 01, 2003, 23:43 »
Well, I've tried MSN6, and it's OK, I suppose.  Can't see how you re-name contacts though, Shaz.   :-\
Offline Shaz
Re:Msg 6
« Reply #14 on: August 01, 2003, 23:45 »
No Simon I thought you could but was mistaken soz. :)
