Author Topic: Quicktime  (Read 2389 times)
Quicktime
« on: August 05, 2003, 21:02 »
Has anyone had problems with Quicktime interfering with other programmes.  Whenever Quicktime is activated on my PC, I lose my scanner and have to re-install :(
Re:Quicktime
« Reply #1 on: August 05, 2003, 21:14 »
Can't say I have Lona :( The only problem I ever had with Quicktime is installing all the different versions that my Son's games require.
What model of scanner do you have?
Re:Quicktime
« Reply #2 on: August 05, 2003, 21:22 »
It's an HP750 all in one printer/scanner.  I don't lose the printer but a message comes up saying scanner not found.
Re:Quicktime
« Reply #3 on: August 05, 2003, 21:29 »
I'm not really sure how Quicktime could be related to a HP750 scanning function Lona.
Have you tried downloading the latest drivers for it from hp.com ?
Re:Quicktime
« Reply #4 on: August 05, 2003, 21:50 »
I'll check again, Adept regarding drivers although I think I have the latest driver.
Re:Quicktime
« Reply #5 on: August 05, 2003, 21:52 »
Yes I seem to remember talking you through installing it recently.
I'll check HPs knowledgebase to see if I can find anything for you :)
Re:Quicktime
« Reply #6 on: August 05, 2003, 22:12 »
:thanks: When I go into HP knowledge base, I am there for the night and end up giving up :(
Re:Quicktime
« Reply #7 on: August 09, 2003, 21:09 »
Any joy, Adept :)
Re:Quicktime
« Reply #8 on: August 10, 2003, 16:14 »
Not really Lona, I'm confused as to which model of HP you have. HP only seem to own up to:-
» hp fax-750
» hp officejet 300 all-in-one
» hp officejet 330 all-in-one
» hp officejet 350 all-in-one
» hp officejet 500 all-in-one
» hp officejet 520 all-in-one
» hp officejet 570 all-in-one
» hp officejet 580 all-in-one
» hp officejet 590 all-in-one
» hp officejet 600 all-in-one
» hp officejet 610 all-in-one
» hp officejet 630 all-in-one
» hp officejet 635 all-in-one
» hp officejet 700 all-in-one
» hp officejet 710 all-in-one
» hp officejet 720 all-in-one
» hp officejet 725 all-in-one
» hp officejet 4105 all-in-one (europe)
» hp officejet 4110 all-in-one
» hp officejet 4110v all-in-one
» hp officejet 4110xi all-in-one
» hp officejet 5105 all-in-one
» hp officejet 5110 all-in-one
» hp officejet 5110v all-in-one
» hp officejet 5110xi all-in-one
» hp officejet 6105 all-in-one
» hp officejet 6110 all-in-one
» hp officejet 6110v all-in-one
» hp officejet 6110xi all-in-one
» hp officejet 7110 all-in-one
» hp officejet 7110xi all-in-one
» hp officejet 7130 all-in-one
» hp officejet 7130xi all-in-one
» hp officejet 7140xi all-in-one
» hp officejet all-in-one
» hp officejet d125xi all-in-one
» hp officejet d135 all-in-one
» hp officejet d135xi all-in-one
» hp officejet d145 all-in-one
» hp officejet d155xi all-in-one
» hp officejet g55 all-in-one
» hp officejet g55xi all-in-one
» hp officejet g85 all-in-one
» hp officejet g85xi all-in-one
» hp officejet g95 all-in-one
» hp officejet k60 all-in-one
» hp officejet k60xi all-in-one
» hp officejet k80 all-in-one
» hp officejet k80xi all-in-one
» hp officejet Lx all-in-one
» hp officejet pro 1150c all-in-one
» hp officejet pro 1150cse all-in-one
» hp officejet pro 1170c all-in-one
» hp officejet pro 1170cse all-in-one
» hp officejet pro 1170cxi all-in-one
» hp officejet pro 1175c all-in-one
» hp officejet pro 1175cse all-in-one
» hp officejet pro 1175cxi all-in-one
» hp officejet r40 all-in-one
» hp officejet r40xi all-in-one
» hp officejet r45 all-in-one
» hp officejet r60 all-in-one
» hp officejet r65 all-in-one
» hp officejet r80 all-in-one
» hp officejet r80xi all-in-one
» hp officejet t45 all-in-one
» hp officejet t45xi all-in-one
» hp officejet t65 all-in-one
» hp officejet t65xi all-in-one
» hp officejet v30 all-in-one (europe)
» hp officejet v40 all-in-one
» hp officejet v40xi all-in-one
» hp officejet v45 all-in-one
Any of those the one you have? ???
Re:Quicktime
« Reply #9 on: August 10, 2003, 20:24 »
Hi Lona,
    Sorry, I can't help you. But I just want to tell you that I have HP Multifunction, and I have no problem.
    I have "HP PSC 2210 All in one" with five functions: "Printer, Scanner, Digital camera cards, Photocopier and Fax". I've just installed "QuickTime 6.3" especially for you. I have Windows XP Home edition.....I have no problem.
    Sorry not to be able to help more.
Re:Quicktime
« Reply #10 on: August 23, 2003, 17:06 »
I've just noticed this thread as I had given up hope of an answer ;D
The HP all-in-one model is HP psc 750, Adept. It's not an officejet. I found the knowledge base article I needed and have connected it into direct power supply instead of multi-point connection. Here's hoping I have no more problems. :)
