Author Topic: Motherboard Audio connections ?  (Read 4434 times)
Re: Motherboard Audio connections ?
« Reply #15 on: August 08, 2003, 20:15 »
Sean
You know I'm only ribbing, and I know you would have come charging in like the Cavalry is you could help audio wise.
Cheers Mate
« Reply #16 on: August 08, 2003, 20:18 »
Well it will either work or it wont Tony :P
It cant do any damage as far as I can tell doing it that way.
Are the headphone/speaker sockets not mounted into a plastic bit at the front ?
If they are then they wouldnt be earthed,unless they were connected to an earthing tag nearby  ???
« Reply #17 on: August 08, 2003, 20:19 »
Of course Tony - wouldn't have it any other way ;) ;D
« Reply #18 on: August 08, 2003, 20:22 »
Piccy coming up, as my batteries are recharged, that should get Simon salavating.
back shortly  ::)
« Reply #19 on: August 08, 2003, 20:28 »
Simon salavating
You really are serving up some disgusting images today Tony :o :wahh:
« Reply #20 on: August 08, 2003, 20:46 »
out of focus but you can see that they are just normal mic/speaker connectors
http://www.tonysugrue.co.uk/frontaudiousb.jpg
« Reply #21 on: August 08, 2003, 21:11 »
I cant see either being earthed on that set up Tony as its a plastic case and the sockets would pull away with the front cover I should think.
Have you got a multi meter so that you can check to see if theres a circuit between the 2 sockets so that we can be sure if they have a common earth going somewhere  ???
« Reply #22 on: August 08, 2003, 22:50 »
Nar, now't like that Sandra, but I keep meaning to get one.
Mind you I ain't even got a set of headphones, because I work on the logic, that if its good enough for me to listen too, every bugger can listen a well, I'm not mean you know.  :) I once had a microphone but I give that away.
Just the other week I gave a plastic Heron away, see what I mean   ::)
« Reply #23 on: August 08, 2003, 23:14 »
Have you got a torch bulb and a battery and a piece of wire?
Disconnect the sockets from the mobo and just see if it will make a circuit using the outside of the 2 sockets as a switch :doggie:
« Reply #24 on: August 08, 2003, 23:28 »
Bloody hell Sandra were you in the girl guides, I'll borrow some headphones from a neighbour tomorrow. and I'll borrow that mic back as well.
« Reply #25 on: August 09, 2003, 14:40 »
Well I tried a mic and headphones in the sockets and they both worked.
Thanks everybody for your assistance and input.
Tony
« Reply #26 on: August 09, 2003, 16:35 »
I'm reluctant to say this, because I know it's a stupid question, and someone's bound to take the pi$$, but if your Motherboard has 'on board' sound, you don't need a sound card do you?
The reason I'm asking is all this talk of sound leads, etc, which I haven't bothered with, as my Asus A7V8X-X has onboard 6.1 sound, the software being on the CD that came with the motherboard.
« Reply #27 on: August 09, 2003, 16:39 »
Some people arent happy with the onboard sound Simon so they disable it in BIOS and add a soundcard.
If you/your friend are happy with the sound then leave it as it is,if not add a soundcard  :-*
