Author Topic: Xp Auto Login  (Read 2484 times)
Offline Robotochan
Xp Auto Login
« on: August 08, 2003, 22:18 »
Hey Does anyone know where the XP auto login function is? I put it on a while ago but it seems to think I put a password in so it put the password in the password field but since there isn't one it gets and error  ???
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline DJ
Re:Xp Auto Login
« Reply #1 on: August 08, 2003, 22:51 »
Its Control Panel > User Accounts and just remove the passwords for your logon.
It should then auto logon.
Hope that helps  ;)
DJ
Offline Robotochan
Re:Xp Auto Login
« Reply #2 on: August 08, 2003, 22:57 »
the problem is I didn't put a password on but it keeps trying to put in a 2 character password  :-\
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline DJ
Re:Xp Auto Login
« Reply #3 on: August 08, 2003, 22:59 »
:doh:
Can't you just ask it not to ask for a password?
Other thank that - I can't think of anything else....
Hopefully a more 'techie' person will be around soon.
DJ
Offline Robotochan
Re:Xp Auto Login
« Reply #4 on: August 08, 2003, 23:01 »
I just need to find out where I can turn it off and on  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline DJ
Re:Xp Auto Login
« Reply #5 on: August 08, 2003, 23:04 »
Isn't it just Control Panel > Users > "Change how users log on or off"
OR
Click a username and remove password?
DJ
Offline Robotochan
Re:Xp Auto Login
« Reply #6 on: August 08, 2003, 23:30 »
Still can't see anything to change it  :-\
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Xp Auto Login
« Reply #7 on: August 09, 2003, 00:04 »
Might work  ;D
Click the Start Button, then click the Control Panel. Then,
click User Accounts in the Control Panel. Select your account name, and then on the left side of the screen, under Related Tasks, click 'Manage my Network Passwords'. In the window that opens, click the passports you want to remove (denoted by (Passport)), and click Remove.
Hookstar  8)
Offline Robotochan
Re:Xp Auto Login
« Reply #8 on: August 09, 2003, 00:15 »
well done what you said, now we play the waiting game  ;) Will find out after the X-mas jobs fair tomorrow  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline Robotochan
Re:Xp Auto Login
« Reply #9 on: August 09, 2003, 12:37 »
That done the biz cheers  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Xp Auto Login
« Reply #10 on: August 09, 2003, 13:04 »
Glad to be of service  8)
