November 27, 2024, 18:31
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
MSN Messenger
Topic: MSN Messenger (Read 10506 times)
TR
MSN Messenger
December 03, 2002, 22:46 »
Greetings folks 8)
Since I have upgraded to the new MSG 5, I have not been able to see the icon on the tool bar... its lost in Space
Has this happened to anyone else that uses Msg or is it just me, I have looked everywhere looks like someone has stole it
The only Icon I have now is on the in tray bottom right,not on the tool bar above, I have right clicked.. nope its not there
Slightly confused Hook
Sandra
Ultimate Member
Re:MSN Messenger
December 03, 2002, 22:53 »
Hook does it not show in the options when you go to customize
Re:MSN Messenger
December 03, 2002, 22:57 »
MSG 5?
There's a new version of MSN Messenger? I missed that one. I must be working too hard
I'll just download it Hook and let you know how I get on
Edit: I can only find version 4.7 for XP. Should I be looking for it anywhere other than microsoft.com
Sandra
Ultimate Member
Re:MSN Messenger
December 03, 2002, 23:00 »
A word of caution Adept,Barra downloaded it a few days back and he had problems as well
Re:MSN Messenger
December 03, 2002, 23:07 »
Hook, if it's a toolbar icon you're after, can you not just drag or copy the desktop icon (create one if there's not one there) to the toolbar?
Sorry if that's stating the obvious!
Re:MSN Messenger
December 03, 2002, 23:08 »
I
love
being the guinea pig for Bill's latest disast great software.
But where can I get it?
TR
Re:MSN Messenger
December 03, 2002, 23:09 »
I've looked everywhere.....
Re:MSN Messenger
December 03, 2002, 23:13 »
I think it might be
here
Re:MSN Messenger
December 03, 2002, 23:19 »
Thanks Simon. I've been there but only got version 4.7 (4.7.0105)
Re:MSN Messenger
Reply #9 on:
December 03, 2002, 23:26 »
Right, I wonder if there's some confusion here over MSN Messenger or Windows Messenger? MSN Messenger is
here
, and if you look at the bottom of the page, it says about different language versions. Click on that, and you will see references to version 5.0. It must just be MSN Messenger that has bumped up to V.5.0
bat69
Loyal Member
Re:MSN Messenger
Reply #10 on:
December 03, 2002, 23:40 »
This is strange, I just downloaded MSN to put n my parents PC and it said it was MSN version 9
, however it worked okay
I wish someone would zap Microsoft
Re:MSN Messenger
Reply #11 on:
December 03, 2002, 23:41 »
Well I'm thoroughly confused now
It would appear that the Win9x version is called MSN Messenger and is on v5 whereas the XP version is called Windows Messenger and is on v4.7
So I clicked on MSN Messenger for Windows and it showed an XP version (v5) which I downloaded and installed with no problems at all.
Hook, the MSN icon appeared without me having to do anything. So all I can conclude is that there was a problem with your installation. Try reinstalling by double-clicking the
MsnMsgs.Msi
from wherever it was downloaded.
Re:MSN Messenger
Reply #12 on:
December 03, 2002, 23:44 »
Well, the XP version, if it's
Windows
Messenger, comes without all the adverts, so surely that's the better choice, regardless of which version number it is?
I'm using the version which came loaded with XP, and have had no problems with it.
TR
Re:MSN Messenger
Reply #13 on:
December 04, 2002, 07:40 »
I have tried what you suggested with the "fix" but still no Icon,Oh well no great shakes.
Thanks for trying anyway. :-[
Hookstar
TR
Re:MSN Messenger
Reply #14 on:
December 04, 2002, 17:58 »
Ok, would it help If I unistalled IE6 and reinstall it.
Im so happy I could just dance all night
MSN Messenger
