Author Topic: Pc Checks?  (Read 835 times)
Offline Solo_
Pc Checks?
« on: August 11, 2003, 04:48 »
Is there anyway i can do a pc check, as i have one faulty part that seems to be causing me trouble, so i need to try and find which part, is there software or anyway ?
Re:Pc Checks?
« Reply #1 on: August 11, 2003, 07:13 »
Solo Hi and god morning.
You could try using PC Pitstop..its ok for a basic check.
Quote from PC Pitstop
Our automated tests will get your PC running fast, stable and secure for free.  Our diagnostic tests are safe, passive evaluations of your system.  Whether you are a guru or a novice, our tests can quickly determine the operating status of any PC.
Don't forget to sign up for a free account.  Once you have run the tests, you'll be able to let some of the mechanics at the Pit, look at your PC to solve any possible problem. No matter what your PC problem, we have the solution here at the Pit.
Hookstar
Re:Pc Checks?
« Reply #2 on: August 11, 2003, 10:24 »
Hi Solo,
This may not do what you want but it might be worth a try.  I've just downloaded it myself, and am looking through it.  It certainly seems to give a lot of information in an easy to use interface, and it's free.
Look for Fresh Diagnosis, at http://www.freshdevices.com/
