Author Topic: CD-RW Problems - ANy Suggestions  (Read 4187 times)
Offline pictec
    • http://pickles.digitalrice.com/
Re:CD-RW Problems - ANy Suggestions
« Reply #15 on: August 20, 2003, 17:59 »
I'm using windows 95. Any files I should be checking for that? Fairly old pc and drive.
I have also tried using a drive cleaner. No effect. I guess the cd burner is just on the way out.
Looks like I need to get myself a new one.
Mark
Offline ketamininja
« Reply #16 on: August 21, 2003, 12:32 »
You could try getting the latest ASPI drivers.
Uh,  haven't worked with them for a while, but if I remember correctly that could help... do a search on google for ASPI drivers for 95.
Offline pictec
« Reply #17 on: August 21, 2003, 13:30 »
Actually I meant 98. Will give it a try though.
Cheers
Mark
« Reply #18 on: August 21, 2003, 13:33 »
I dont know if there are any firmware updates for your CD Writer but they may help  ???
Offline greenking
« Reply #19 on: August 21, 2003, 18:23 »
You have checked that it's not just a bad batch of blank cd's you have Mark  ;D
Offline lobo
    • http://www.burnleywood.com
« Reply #20 on: August 21, 2003, 18:24 »
Simulated burns work fine.
CD write no good
CD-R faulty, if its a couple of years old could be a faulty laser
try in another PC if possiable, and then buy a new one you can get one for the price of a couple of dozen blank CDs
Brian ;D
Homer   , The Odyssey, line 1
« Reply #21 on: August 21, 2003, 18:40 »
Yes, you can easily pick up a new CD-RW for under £30 - for example, take a look at this page, from ebuyer.
Offline pictec
« Reply #22 on: August 22, 2003, 14:41 »
Useful page. Will buy a new drive when my next pay check is in next week.
Just done a further test of the drive by downloading the diagnostics program BurnInTest. Get the following error message on the cd drive:
CDROM, D:Error while searching for files on data CD/D
CDROM, Path: D:\*.*, Cycle:0, Error Code 21
Don't know if that gives anyone any ideas.
Mark
